Feature requests and bugs in 9beta 3
COW Forums : DaVinci Resolve
justin lovell
on Sep 3, 2012 at 4:50:39 am
Is anyone from BM moderating this? (just wondering if this is being read, or if there is a better way to reach out).
Great Work on the new release.
Some much needed changes, that shouldn't be difficult to implement.
1. Add more speed changing options.
- in media bin, right click on clip, Video Frame rate : allow custom frame rates. (I do film restoration work and much of it is at 16/18fps or custom frame rates).
2. Allow custom timeline frame rates
- Custom, 16/18fps with the ability to render (deliver) downstream at 23.98 or 29.97.
3. in Timeline allow option for changing speed to be selectable as % or frame rates. ie. used to allow me to change the speed to 18fps, now it only has speed change in 100% and % increments.
4. Fix speed changing bug
- clicking on clip to change speed, then redrag the clip to make it the right length, but after extending the length of the clip, it freezes frame at the point where you extend the clip. If you reapply the speed change the clip eliminates the freeze frame and speed changes properly (now that it is extended visually to the right length in the timeline).
Looking forward to the next release to fix some of these issues!
Justin Lovell /Assoc. CSC
Sascha Haber
Re: Feature requests and bugs in 9beta 3
on Sep 3, 2012 at 6:27:46 am
I agree to all of the above.
Just inverting the percentage gives a wrong result too.
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
Gabriele Turchi
on Sep 3, 2012 at 11:53:41 am
yep , improving the speed changes is the next big thing i am waiting ,
sooooo many times i have to leave resolve and pass along shots to others (or i have issue with dynamics applied on shots that have speed changes )
1)because of the quality of the speed changes in Resolve (only frame duplication )
2)because the timeline/shot does not ripple when manually apply a speed change
3)because a dynamic or tracking applied on a shoot on XML that speed change applied on , does not properly translate to the master session (in order to render all the shots nice and clean )
Davinci Resolve Control Surface
Cubix desktop 4
2 Red Rockets
HP Dreamcolor
Panasonic 58PF Plasma
© 2018 All Rights Reserved
