C-MODE sort by Reel
COW Forums : DaVinci Resolve
James Scott
C-MODE sort by Reel
on Aug 30, 2012 at 4:48:21 am
When in C-Mode I can only seem to have it sorted by Timecode even though I have the setting on to use Reel name first. I searched through the forum and this seemed to be a feature missing in 8 or did not seem to work properly. Am I missing something or does this still not function in v9 with sorting by Reel Name first. I am working on a multi-clip show and this is quite important for organizing.
Sascha Haber
Re: C-MODE sort by Reel
on Aug 30, 2012 at 8:33:57 am
Yes, I totally agree, this is an important thing to fix.
I am also working on a movie shot over 40 days and I have proper reel IDs based on the Alexa file names.
When switching to C Mode one would expect it would first sort by reel name and then by time code .
This would enable me to see the shots next to each other and work on the colors respectively.
But it just sorts it by time code so they shot are all over the place because every day uses basically the same time code from 10:00:00:00 (start of day) to 20:00:00:00 (end of work day )
So what we need is the function to sort like this
1. A055C002_120508_R348 - 10:00:00:00
2. A055C002_120508_R348 - 11:00:00:00
3. A055C002_120508_R348 - 14:00:00:00
4. A055C005_120508_R348 - 10:00:00:00
5. A055C005_120508_R348 - 13:00:00:00
6. A055C005_120508_R348 - 18:00:00:00
and so on... First reel ID, then timecode
Here a snapshot to illustrate the problem, the timeline is fragmented
thanks in advance :)
Another thing is that if you press play in C-Mode, Resolve stills plays back in A-Mode.
The makes it a little hard to judge similar shots back to back
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Fred Ricci
on Aug 30, 2012 at 9:02:20 am
Totally agree, I use c mode all the time, I think its a major feature. We should be able to have more sorting options.
NEHALEM OCTO 2,26
GT 120
GTX 285
8 Giga RAM
SOFT RAID 8 Tera
Wave
Eizo 243 + Hdlink displayport
DAV, COLOR, FINAL CUT AND MEDIA COMP
Mel Matsuoka
on Aug 30, 2012 at 7:31:27 pm
[Sascha Haber] "Another thing is that if you press play in C-Mode, Resolve stills plays back in A-Mode.
The makes it a little hard to judge similar shots back to back "
Yes, this is a huge gripe of mine regarding C-sort mode! While it's great to know that Reel+TC sort has been "conceptually" added to R9, not having real C-sort playback is a bummer of a workflow, esp. when working on long-form work.
+1 to making this a feature request!
Rohit Gupta
on Aug 30, 2012 at 10:21:40 am
Hi James,
Thanks for reporting this. We hope to have a fix for this in the next update.
Regards,
Rohit
Sascha Haber
on Sep 3, 2012 at 1:38:20 pm
Perfect ! Thanks :)
A slice of color...
RAID0 8TB
Extreme 3D+
