Resolve 8.2 on a retina - 2nd monitoring out/cuda issues
COW Forums : DaVinci Resolve
Jeff Brown
on Aug 24, 2012 at 4:18:21 pm
Hi all
Running a 15" Retina with a Magma (Rocket + esata) enclosure.
Resolve is saying the Nvidia 650M is not supported. I'm on latest CUDA 5.
Also can't figure how to get a 2nd monitor (24" dreamcolor) out over HDMI - (Works fine doing that in Scratch)
Any help appreciated!
Jeff Brown
Dwaine Maggart
Re: Resolve 8.2 on a retina - 2nd monitoring out/cuda issues
on Aug 24, 2012 at 9:48:04 pm
Look in the Energy Saver section of Mac System Preferences, and uncheck the Automatic Graphics Switching mode.
Resolve has limited support for dual GUI displays. All you can put on a second GUI display are the WFM scopes.
If you are wanting the second display for grading, you will need to use a BMD UltraStudio 3D or Intensity Extreme box connected via Thundebolt. And then select that device in the Resolve Preferences window in the Video I/O area.
Dwaine Maggart
Blackmagic Design DaVinci Support
Jeff Brown
on Aug 28, 2012 at 9:41:12 am
Thanks Dwaine
Got it working now. Threw a blackmagic extreme in the Magma and all works fine.
Cheers
Jeff
