3 way too responsive
COW Forums : DaVinci Resolve
Matt Harris
on Aug 23, 2012 at 11:35:54 pm
I always hated how sensitive the 3 way color wheels were with a muse in resolve when grading prores files. I just downloaded a raw file from the new BMD camera and it is way better. Is there any way to change the sensitivity of the color wheels when using prores and a mouse?
Kevin Cannon
Re: 3 way too responsive
on Aug 24, 2012 at 12:32:53 am
Hi Matt,
What kind of ProRes files give you trouble? Are they Log-C or are you adding a LUT at some point in the chain?
I believe that since Resolve is applying the changes to a fully decoded RGB image, and that there wouldn't be a difference based on the source media. But there would be a big difference if you color before vs. after a LUT.
Cheers,
KC
Prehistoric Digital
Matt Harris
on Aug 24, 2012 at 12:57:33 am
No Luts applied. I barley have to move the highlight wheel before I get a huge color cast! I have no idea why it does this.
Matt Harris
on Aug 24, 2012 at 12:58:32 am
Also, its just a ProRess 422 file convert from 5dmkii footage in final cut.
Sascha Haber
on Aug 24, 2012 at 6:13:52 am
Sure you are using V 9 ?
In 8 I agree, but 9 is totally smooth
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Matt Harris
on Aug 24, 2012 at 6:17:32 am
Yea its v9. Is there not a setting for the sensitivity. I couldn't believe how much easier it was with the DNG file. I could push the wheels about halfway before it really started to alter drastically.
Matt Harris
on Aug 24, 2012 at 7:10:32 am
Heres an example of a neutral image and then a heavy color cast from minimal adjustment to the highlights. This is a prores 422 file from FCP :
Robbie Carman
on Aug 24, 2012 at 6:25:33 pm
well with out seeing your scopes - the sky is all highlights and you have made a push ( not a huge one but a push none the less. Perceptually, I've always found that highlight corrections are more "sensitive" to slight adjustments
Robbie Carman
Colorist and Author
Check out my new Books:
Video Made on a Mac
Apple Pro Training Series DVDSP
From Still To Motion
An Editors Guide To Adobe Premiere Pro
Twitter
Blog
Matt Harris
on Aug 24, 2012 at 7:35:10 pm
Same thing happens in the midtones. My point is I can take a scene from a DNG raw file and push it way further before this strong of a cast happens. It feels much better and I'd love to grade that way. Thats the one thing I like about colorist plugin vs resolve.
Ernest Ratliff
on Aug 24, 2012 at 8:47:18 pm
That seems like a pretty big movement to me, you should see a rather pronounced color cast on any footage if you move it that far towards one color. I just replicated the same values from your picture with the BMCC sample DNG, and it has a very noticeable color cast.
If the wheels are too sensitive while using a mouse, maybe try doing all your adjustments with the primaries, I think it's easier to have fine grained adjustments using those with the mouse, though they are slower than the wheels.
Matt Harris
on Aug 25, 2012 at 10:49:34 am
Thanks ernest. I realize if you replicate the values, then it will be the same. But did replicating those values put your ball on the 3 way that close to the center?
