8.2 Alpha channel
COW Forums : DaVinci Resolve
andrew sableton
8.2 Alpha channel
on Aug 23, 2012 at 7:34:50 pm
I have a ProResHQ FCP7 sequence with ProResHQ media except for some FX material that is in animation codec with alpha channels. Should I bake these animation codec clips as ProResHQ and then somehow extract a matte from them to import into a node in DAVINCI? Will this then work in a round trip?
I'm a little confused as to how to get this to work.....
S
andrew sableton
Re: 8.2 Alpha channel
on Aug 23, 2012 at 7:36:50 pm
Also Davinci seems to refuse to see the animation codec QTs at all - I look in the folders where they should be through the DAVINCI browse page and these clips do not appear, although they are in the OSX finder....
Joseph Owens
on Aug 23, 2012 at 9:07:58 pm
So, a couple of things.
First of all, if you go looking at the http://www.blackmagicdesign.com/media/2588311/davinci_resolve_8.2_supported...
you won't find the Animation codec. It won't appear on a lot of lists.
Its a bit long in the tooth as a "lossless" codec, its only adavantage now being that it is one of the few that can carry an alpha channel, but then there's ProRes 444.
Resolve 9 can use alpha channels for matte purposes, but not 8.2. You will have to extract the alpha channel somehow and export that (exact length of the original clip) as a recognized codec and attach it to the source clip as an external matte. You cannot export an alpha out of Resolve.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
andrew sableton
on Aug 23, 2012 at 9:20:01 pm
Ok thanks JPO - what would your process with FCP be to 'extract' the alpha?
S
Sascha Haber
on Aug 24, 2012 at 6:15:13 am
Please just upgrade, you will love it and need to learn a cumbersome workaround .
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Eric Johnson
on Aug 24, 2012 at 8:32:56 pm
For a luma matte, you can load your clips in the viewer, change your view from RGB to ALPHA. You should see a B+W of what your alpha should be... and export.
I'm sure there are other ways. That's the way I know of.
