Anamorphic
COW Forums : DaVinci Resolve
stig olsen
Anamorphic
on Aug 23, 2012 at 5:51:59 pm
We shot a commercial with old russian lomo lenses that comes out anamorphic.
In Recine we stretched them out (2:1) for offline.
When conforming them in Davinci, I can't find a way to do the same. It is possible to stretch to fill all corners and so on the input section, but not to stretch out to the normal frame with black under and on top.
Any suggestions?
Stig
Charles Haine
Re: Anamorphic
on Aug 23, 2012 at 5:57:16 pm
I built a pre-set in the Output tab of the format room for a 2x1 stretch that worked well on my last Anamorphic job.
http://www.dirtyrobber.com
stig olsen
Re: Anamorphic
on Aug 23, 2012 at 6:59:09 pm
Ok, so there is no other ways to do it?
Why do you make the preset in the output tab, and not the input tab?
Sascha Haber
Re: Anamorphic
on Aug 23, 2012 at 7:25:36 pm
Seems brokern in v9b3.
Before it was possible to adjust the Timeline and it would stretch accordingly
NTSC DV is also broken...still...
A slice of color...
DaVinci 9b3 OSX 10.8
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
Colorist / Aerial footage nerd
http://vimeo.com/saschahaber
Javier Sanchez
Re: Anamorphic
on Aug 23, 2012 at 7:25:19 pm
wich version of resolve do you have?
yesterday i get a project on anamorphic lens, and is already out, but i need to know if you are on v9.
Javier Sanchez
Head Of Technology
Gama Digital
stig olsen
Re: Anamorphic
on Aug 23, 2012 at 7:27:21 pm
9 Beta 2
Javier Sanchez
Re: Anamorphic
on Aug 23, 2012 at 8:50:53 pm
Well is easy then: on the media pool, right clic on the file> clip atribute>Video>pixel aspect ratio> try cinemascope (it work for me) if not there is 16mm anamo or 35mm anamo.
Regards
Javier Sanchez
Head Of Technology
Gama Digital
stig olsen
Re: Anamorphic
on Aug 24, 2012 at 8:44:29 am
Thanks, that was it!
Ryan Wu
Re: Anamorphic
on Jan 11, 2013 at 4:49:10 pm
Will this work with resolve lite 9?
frozen ryno
Re: Anamorphic
on Jan 25, 2013 at 3:43:04 pm
I am looking at doing this as well but getting mixed messages between the forum and ARRI.
I tried the cinemascope setting and it deqsueezed and looked good.
However Arri folks tell me:
"You can use the desqueeze using the pixel aspect. But please keep in mind that the framing of the clips will not be correct. You also have to scale the image by a factor of 1.046 ( 1920 / 1836 ).
***{I can't find those settings in DR Lite 9.1}**
The ARRI ALEXA captures a 4:3 2K ProRes file in the resolution 2048x1536. When using an 2x anamorphic lens the picture aspect is 1:2.67. The 2.39 image is centered having extra image data to the left and right with a total pixel width of 1836. When only desqueezing the image you will have an image which is to small and has extra picture information left and right with an picture aspect of 1:2.5 inside your HD image."
Can anyone clarify this for me.
I am using DaVinci Resolve 9.1 LITE
It rendered fine just using the cinemascope setting and the scale image to fit. I did this using ARRI test footage (parade)but don't have a rack leader to check it against to see if it is cropped on the ends.
I want to create prores 422 LT dailies
Arri says:
- Create a 1920x1080 project. Done
- Create a "InputSizingPreset" with a width of 1.046 and height of 0.523. ( 1920 / 1836 = 1.046 /2 = 0.523 )
****CANT FIND THIS IN RESOLVE 9.1 LITE****
- Apply your preset on all your anamorphic ProRes files. Easiest is to select the files on the Media page and right click and choose "Change Input Format Preset for Clip" and choose your previously saved preset.
- Render away.
- please also check in the Project settings, that Image Scaling is set to "Center Crop no resizing" for both options. ****get super streched image***
Confused.
Any insight would help
THX
R
THX
Charlie Anderson
Re: Anamorphic
on Feb 19, 2013 at 5:00:27 pm
Input sizing is under the COLOR tab, the 7th icon from the left (or directly above the color wheel icon in the color tab, you can't miss it, it's the tab that looks like something is being resized.) You can add those numbers in there.
Bruce Newton
Re: Anamorphic
on Jan 16, 2014 at 9:45:09 am
Thanks everyone this is working well for me, but do we have to change input settings for each take on Resolve?
I have created a preset but how do I apply it to the whole time line?
If it can be done I'm sure i'll have figured it out by the time I get a reply, but looking good so far.
I'm converting ARRI Log C files shot on anamorphic 2 X.
Finishing in 16 x 9
Only God and the DP know why we would put ourselves through this kind of torture to get a frame that is 16 x 9 anyway.... and there are no flares on this job ....
sasi evani
Re: Anamorphic
on May 8, 2014 at 11:02:30 am
so ..did u figure it out ? how to apply that input scaling preset to the whole timeline..
am a bit stuck..
thank you..
regards,
Sasi
