MacBook Pro Resolve Lite 9 Database fix request
COW Forums : DaVinci Resolve
Dave Pickett
on Aug 21, 2012 at 4:34:52 pm
Hi BMD,
Could I get the more detailed info on repairing the database postgres install? I tried the rename postgres file and reinstall work around on version 8 with no luck and so far have the same result with 9.
I am using a 2009 MacBook Pro 2.53 Intel Core 2 Duo with 4 GB 1067 MHz DDR3. NVIDIA GeForce 9400M 256 MB
Mac OSX 10.7.4
Dave
Dave Pickett
Colorist
Jam Edit - Atlanta
http://www.jamedit.com
http://www.davepickett.com
Dwaine Maggart
Re: MacBook Pro Resolve Lite 9 Database fix request
on Aug 21, 2012 at 5:54:35 pm
Hi Dave,
Contacting us directly at davincihelp (at) blackmagicdesign (dot) com would facilitate this.
Do you have an existing database with stuff in it you care about?
If you are using V9, you can also use the new Disk Project based database, and not mess with PostgreSQL at all. Setting this up is detailed in the new V9 beta 3 Resolve manual, starting on page 609.
Dwaine Maggart
Blackmagic Design DaVinci Support
Dave Pickett
on Aug 21, 2012 at 8:22:57 pm
Thanks Dwaine for the advice and the direct email. I dont have an existing database for my MacBook so I will give the new Disk Project a go.
Dave
ps This beats troubleshooting an internal TLC in '03 or an aging 2K in '07 I'd say.
Dave Pickett
Colorist
Jam Edit - Atlanta
Dwaine Maggart
on Aug 22, 2012 at 12:57:26 am
Hi Dave,
I was just noticing what you said your system specs were. I didn't pay much attention earlier, as they were not relevant to PostgreSQL issues. If you ONLY have a 9400M GPU, I don't think Resolve will run on that. You need at least a mid-2009 MBP that has both a 9400M and a 9600M GPU in it. If your MBP does not have the 9600M, it's almost certainly not going to run Resolve.
Dwaine Maggart
