F65 SR media not showing up in media pool
COW Forums : DaVinci Resolve
Adam Watson
on Aug 21, 2012 at 4:26:16 pm
I'm doing camera tests and have footage for Arri ProRes, Arri RAW, Epic R3D, F65 RAW and F65 SR. All of them load up fine in Resolve 9 except for the SR media, it won't show up at all, it doesn't even see that the files are there. What am I missing? I have the codec, I can even play the media from the Finder window without issue. Any ideas? I am just learning Resolve so it could be really simple.
Juan Salvo
Re: F65 SR media not showing up in media pool
on Aug 21, 2012 at 4:27:12 pm
Did you change the directory structure of the media? I've got SR media loaded without issue.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Adam Watson
on Aug 21, 2012 at 4:38:38 pm
nothing like that, it doesn't even show up in the library. open an F65 RAW folder, there is a clip. Open an F65 SR folder, no clip. open the same folder in Finder, there is a clip. It's like it needs a plugin or something to see it.
Juan Salvo
on Aug 21, 2012 at 4:50:32 pm
Just tested it. This is in Resolve 9b3... but has worked in all prior versions that I've tried.
Have you modified the files in anyway? Changed the card structure? Can you view them in SR viewer? How did you create the files?
BTW, my Resolve machine does not have the sony plugin installed.
David Bernstein
on Aug 21, 2012 at 6:50:03 pm
I have the same problem, actually. F65 Raw (lite) files load fine, but the SR files do not appear in the Media Browser at all. Scratch will load them fine on the same computer, but neither Resolve nor the Sony SR viewier will see these particular mxfs. I have also loaded OK them in Baselight at a different location. In my case, I have SR 444 16bit lin clips copied off the SR memory card. I suspect it's a 16bit issue.
DB
Juan Salvo
on Aug 21, 2012 at 6:53:39 pm
What OS version are you guys running? There was an issue reported by Sony with Os X 10.7.4. I'm running 10.7.3, BTW.
David Bernstein
on Aug 21, 2012 at 6:59:58 pm
Sorry, meant to include, Win 7 x64 running the latest build of Resolve v9b3 and Scratch 6.1
DB
Adam Watson
on Aug 21, 2012 at 7:19:46 pm
Mac OSX Lion,
also SR 444
I haven't tried using the SR viewer, can't do that right now though.
Adam Watson
on Aug 21, 2012 at 7:22:59 pm
Oh and the OS is 7.0.4
Adam Watson
on Aug 21, 2012 at 7:24:10 pm
so is there maybe a solution besides upgrading the OS?
Rohit Gupta
on Aug 21, 2012 at 11:45:11 pm
Are you able to send us the file link at davincihelp (at) Blackmagicdesign.com?
David Bernstein
on Aug 22, 2012 at 6:13:52 am
Hi Rohit,
I am uploading the file to my dropbox, will send a link after it's completed.
DB
Adam Watson
on Aug 22, 2012 at 4:16:20 pm
I'm currently uploading and sending you a clip at that address. Thank you very much.
Dwaine Maggart
on Aug 22, 2012 at 10:56:14 pm
Hi Adam,
David sent his clip, and it works fine on Windows and Mac systems (10.7.4 and 10.8) running Resolve 9 beta 3.
It also works on a very low end Windows system running 8.2.2 Lite.
I have not seen your file Adam. Have you sent it yet? If so, can you recheck you sent it to davincihelp?
Are you on a real Mac, or a Hackintosh of some sort?
Adam, you also mentioned you were using OSX Lion, but then said your OS version was 7.0.4, which is not a valid OSX version. Can you clarify that?
Dwaine Maggart
Blackmagic Design DaVinci Support
Adam Watson
on Aug 22, 2012 at 11:16:12 pm
My apologies. I had been replying while doing other work so that's why it was so scatterbrained. I'm on a real Mac Pro tower and it's version 10.7.4
I had been trying to upload a clip but the connection is perhaps too slow so it kept resetting the upload. I quit it and will try to upload it tonight from another location instead.
Dwaine Maggart
on Aug 25, 2012 at 1:02:18 am
Hi Adam,
Like Daivd's clip, your clip shows up fine in Windows and Mac Resolve V9 beta 3 on our systems.
Dwaine Maggart
Adam Watson
on Aug 27, 2012 at 5:13:54 pm
so what could it be? because as you point out there is no reason it shouldn't work. Any suggestions for something else I could try?
Adam Watson
on Sep 6, 2012 at 5:38:31 pm
Again, any suggestions as to why it won't work on my Mac pro and how to fix it? Thank you.
Danny Jenkins
on Nov 15, 2012 at 2:44:23 am
Sorry to revive this thread but I'm also having the same problem.
I can import F65 .mxf media from a previous project: HDCAM-SR 444 1080p25
but not HDCAM-SR HQ RGB12 1080p25
Clips just don't show up in the folders.
They open in Quicktime and Final Cut 7 perfectly.
I'm using the Lite version of Resolve 9.
I think the latter of my material is 12 bit... is that the problem and is there a way to fix it?
Best regards,
Danny Jenkins
Danny Jenkins
on Nov 15, 2012 at 3:49:25 am
UPDATE - The new Resolve 9.0.3 Lite solved it for me.
Best regards,
Danny Jenkins
alex B Carr
on Dec 18, 2012 at 3:13:29 am
If you turn metadata off in the PC-4 the clips will load in Resolve. I was working on Set and I discovered this, it seemed to appear while shooting above 60fps in HFR mode, we had a lockit box plugged in and that was the issue. The clips didnt load into F65 RAW viewer or Davinci.
Umut Sakallioglu
on Feb 14, 2014 at 5:06:38 pm
Hi there
I also failed to see my SR footage shot with a F65 in resolve.
But can view them with SR viewer.
I was going to ask if you can share the right folder structure for SR clips.
Thanks in advance!
Umut.
