Mixed R3D frame rates
COW Forums : DaVinci Resolve
John Sellars
on Jul 15, 2012 at 7:25:20 pm
I have a project that was shot on the MX in 23.98 in the US, and 24 in another country. The R3D's were transcoded to ProRes for FCP 7 using both Log and Transfer, and Redcine. The FCP timeline has these mixed frame rates in the edit, and the sound design has been completed.
I want to work with the raw R3D files in Resolve (lots of clipped highlights in the ProRes files, plus I want the option of doing a 4k DCP). My question is, even if the 24fps ProRes clips were flipped to 23.98 using Cinema Tools, and re-cut in, what happens when I relink to the R3D's and round trip? Will Resolve force 23.98 on all clips and will everything line up? I don't have any of the media yet to test, just want to be ready…
Joseph Owens
Re: Mixed R3D frame rates
on Jul 15, 2012 at 9:50:09 pm
Haven't had to reconcile something like this, but my bet is that on a clip-by-clip basis you won't notice any difference. Even SR decks can correct for the 1000/1001 pitch difference in real time playback, and certainly the raw pickup points won't be different.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Marcus Smith
on Jul 15, 2012 at 11:48:20 pm
Yes, davinci will force one frame rate upon everything. To ensure you have a frame accurate conform I would change everything to 23.98 and check it in fcp before going out to davinci.
Gabriele Turchi
on Jul 16, 2012 at 2:17:03 pm
last week i had almost the same issue but considerably worse : edit done mixing 23.98 and 29.97 on a 29.97 timeline .
off course FCP in that circumstance add pulldown (actually it repeat 1 frame every 5 ) and that is it , but resolve cannot do that , so as far as i know the only way to finish the R3D is to have 2 sessions : one for the 29.97 (EDL prepped on a 29.97 timeline ) and one for 23.98 having those shots copied and pasted on a 23.98 timeline (for edl)
than final conform somewhere else . it would be cool if resolve could apply progressive pulldown to shots for this kind of circumstance ...
unless there is a workaround for this already ..
g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX470
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Ultrascope
John Sellars
on Jul 20, 2012 at 6:19:35 pm
Thanks all, I am still waiting for the media…
alban egger
on Jul 24, 2012 at 4:09:10 pm
I have this problem with 720p25, 720p50 and 1080p25 material mixed in one 720p25 FCPX-timeline. Resolve won´t open the XML.
So the only possible workaround is to select the various frame rates (FCPX roles system might be handy here) and export them each as one session?
