RAID Recommendations
COW Forums : DaVinci Resolve
Jeremiah Belt
on Jul 9, 2012 at 5:27:27 pm
Building a new workstation to replace my 6 year old Mac Pro for DaVinci Resolve and Motion Graphics. Any thoughts or opinions on a 6 drive RAID 5 vs an 8 drive RAID 5 of the same storage size (either 8 or 12TBs). Are the 8 drives that much faster and worth the risk of the extra disks in regards to bad sectors and read/write errors? Also considering RAID 6 if it isn't a huge performance hit.
Any help or thoughts would be greatly appreciated. I would really like to build a smaller system in a smaller case by going with 6 drives...but I don't want to create future expansion issues by limiting my drive space and case size.
Joakim Ziegler
Re: RAID Recommendations
on Jul 9, 2012 at 7:16:30 pm
A lot would depend on your RAID controller.
Joakim Ziegler - Postproduction Supervisor
Jeremiah Belt
on Jul 9, 2012 at 7:21:08 pm
I will be using a Areca ARC-1882IX-12 6Gb/s SAS/SATA RAID Adapter with 4GB of cache in a PCIe 3.0 full 16X slot. The same setup that ProMax uses for their ProMax One. They get around 1200MBs off of 6 drives in RAID 5.
Sascha Haber
on Jul 9, 2012 at 9:55:36 pm
That sounds pretty ... ridiculously high.
I am getting 1500 out of our GlobalStor, which uses 2 of those controllers in parallel and 10 disks each.
1200 from 6 Drives ? SSD drives maybe.
But hey, if they have a recipe , do it exactly the same way..
A slice of color...
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
ICA Instructor
http://www.icolorist.com/Sascha.html
Jeremiah Belt
on Jul 9, 2012 at 10:02:27 pm
That's what I thought as well when I heard and saw the benchmark at NAB this year. Part of me wonders if they had the cacheing enabled on their AJA benchmark tool. I plan to copy their setup exactly but probably with 8 drives. So we shall see.
Joakim Ziegler
on Jul 9, 2012 at 9:58:08 pm
That's a very good controller, so you're covered there. I think part of the question is, how much speed do you need? Uncompressed HD is less than 200 MB/sec, typical 2k is less than 300MB/sec per stream. That controller with 6 drives should give you around 500-600 MB/sec with 6 drives in RAID5, which is enough for most work.
Going up to 8 drives might give you another 200MB/sec extra max, but do you need it? Also, I'd do RAID6 if I went above 8 drives, but with 8 RAID5 is probably ok, provided you make sure your ventilation is adequate.
Jeremiah Belt
on Jul 9, 2012 at 10:07:40 pm
Yeah those numbers seem realistic to me. I'm getting 560MBs tops off my 8 drive external SAS connected to an old ATTO R380 in a 4x slot instead of 8x.
Most of my color grading deliverables lately have been at 4K recently. Plus when I'm doing my Motion Graphics work your talking about sometime over 100 layers in AE with 5-8 of those being 1080P to 3K video sequences. So the faster the better.
I just would really like to have a smaller system footprint with the 6 drives instead of the behemoth tower that will be required with the larger array. But I don't want to be stuck with only 6 drives and no upgrade room and regret it I suppose.
Sascha Haber
on Jul 10, 2012 at 6:20:24 am
If 560 is enough, get 4 internal ones...
I am getting that from mine...when they are empty of course.
A slice of color...
RAID0 8TB
Extreme 3D+
ICA Instructor
Michael Cinquin
on Jul 10, 2012 at 7:18:20 am
I would suggest not to go with Raid 5, but Raid 6, or to have a very good read at http://www.miracleas.com/BAARF/.
I have had Areca controllers for years and woul'nt recommend them. Tech support has been very unresponsive. I have to work with lots of options disabled (including Tagged Command Queuing, including Read Ahead), because otherwise the Areca reliably make the computer crash when the array is > 60% full (2x12 sata-disks in SAS expanders). So I get degraded performance. It's a Macintosh driver problem. "Realibly crashes" : consistent accross Areca Cards (1680 and 1880), computers (different mac pros), hard drives (consumer and enterprise-grade, operating systems (Leopard and Snow Leopard), card firmware and drivers. If I had to start from scratch I would go with Atto. For the moment I don't, because I prefer the devil I know, I need those Raid volumes, performance though degraded is still fine for 2K DPX read/write at the same time (> simultaneous 300 MB/s read & write) and the stability of the Raid Volumes (one Raid 6 on one computer, one Raid 60 on an other) has been perfect.
It makes no sense to test a RAID array with something like Aja System Test. The Write test are not accurate because the Raid cache speeds up enormously the thing (I have 3 GB RAM on my Raid Card, those are filled almost instantly, 16 GB is not enough). Then the Read test are not accurate either, because the write cache is still getting emptied. I would suggest going with http://diglloydtools.com/disktester.html ... or duplicating a dpx full of DPX, or R3D (whatever you work with), and check out Activity Monitor to see what is the real-life read/write speed.
Michael Cinquin
Final Cut Pro - Avid Media Composer editor
DaVinci - Color - Baselight colorist
Color profiles for Color
http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode - Keycode calculator
