OT: Macvidcards GTX 480 problem
COW Forums : DaVinci Resolve
Russ Johnson
on Jul 5, 2012 at 3:10:14 pm
I'm posting here because users on this forum have experience with Macvidcards' Nvidia cards. I could really use some help.
I bought and installed a GTX 480 from Macvidcards for use with Adobe CS6 PP. When I try to enable the GPU hardware support in Premiere "Project Settings" I can not select "Mercury Playback Engine GPU Acceleration (Open CL)" for "Video Rendering and Playback" because it is grayed out and not available. I downloaded and installed the CUDA driver from Nvidia. Nvidia system settings report drivers as CUDA driver: 4.2.10 and GPU driver as 7.18.18 270.05.25f01.
My system: MacPro 3.1, OS 10.7.4, Premiere CS 6.0.1, 16gb ram, Macvidcards' flashed/modified Nvidia GTX 480.
Help with this is very much appreciated.
Pepijn Klijs
Re: OT: Macvidcards GTX 480 problem
on Jul 5, 2012 at 3:46:22 pm
Go to the prem pro app and choose 'show package contents'. Find a text file with 'cuda cards' in its name. Open it and add your card to the list, exactly like the cards described there already. Save. Viola!
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl
Juan Salvo
on Jul 5, 2012 at 3:55:55 pm
As Pepijin said, you need to manually add the card to the approved card list. Here is a good video walk through.
http://film-sound-color.tumblr.com/post/26071716910/how-to-enable-gpu-cuda-...
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Russ Johnson
on Jul 5, 2012 at 4:13:31 pm
Thanks so much guys. I had tried this, but must have typed in the name of the card wrong. Tried it again and it worked like a charm.
Should I also do this on the "opencl_supported_cards.txt" file?
Regards,
Russ
Jonathon Lee
on Jul 5, 2012 at 6:54:33 pm
I had to do the same for my gtx570 from them. I had to make a similar change for after effects as well.
