Clips not in the correct place
COW Forums : DaVinci Resolve
Hisonni Johnson
on Jun 24, 2012 at 6:07:40 am
I have imported an XML into Davinci resolve lite. The clips are importing fairly well but for some reason there are a bunch of clips that are in the wrong place in the timeline. Is there any way to fix this. A better way to import or way to get the correct clip in the place of the incorrect clip. Thanks guys.
Best wishes
Peter Chamberlain
Re: Clips not in the correct place
on Jun 24, 2012 at 6:50:41 am
Hi, sounds like you have clips with the same timecode. Or your clips have diff. frame rates. Try flattening the clips to one frame rate or select to use reel number on the settings page.
Peter
Hisonni Johnson
on Jun 24, 2012 at 2:50:02 pm
Thank you soooo much for the tip. Ill give this a try! I had no idea what else to try.
