Software Issue on Resolve 8.2-1 version
COW Forums : DaVinci Resolve
Ramesh Swami
on Jun 19, 2012 at 5:53:26 am
Hi
This is Ramesh from India, we are using Resolve system on Mac here is the Config of our system Mac OSX Lion version 10.7.3, 2x2.93 Ghz 6 core Intel Xeon, 15GB Ram, Macpro Mid 2010, Nvidia Geforce GT120.
And we have install Nvidia Geforce GTX 570 for playback.
1. We are not able to show the driver on system perference of Geforce GTX 570, we have updated the cud a drivers also, currently the cuda version is 4.2.10 , but still the drivers is not showing.
we are facing a issue which launching Resolve software 8.2-1 , error showing :-
1. Resolve has determine that the display GPU is also being used for image processing & so performance may be limited. For maximum performance, we recommend that you use a system specification from the configuration guide. You can find the guide in the support section of the Blackmagic Design website
2. Resolve has determined that the hardware configuration you are using is not optimal & so performance may be limited. The following unsupported cards are being used for image processing : Nvidia geforce GT120. For maximum performance, we recommend that you use a system specification from the configuration guide. You can find the guide in the support section of the Blackmagic Design website.
Kindly send me the link of the drivers of detecting Geforce GTX 570 , waiting for your reply.
Regards,
Ramesh.
Juan Salvo
Re: Software Issue on Resolve 8.2-1 version
on Jun 19, 2012 at 6:25:25 am
Nvidia drivers for 10.7.3:
http://www.nvidia.com/object/macosx-270.00.00f01-driver.html
For 10.7.4:
http://www.nvidia.com/object/macosx-270.00.00f06-driver.html
ONLY INSTALL THE ONE FOR YOUR OS.
Based on what you wrote, that would be 10.7.3.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Ramesh Swami
on Jun 19, 2012 at 9:10:37 am
Thank you very much Juan, we have download the 10.7.3 drivers link, now the drivers has been installed successfully, now both the cards are showing simultaneously.
Thank you
Regards,
Ramesh.
