Not reafing RMDs right when conforming...
COW Forums : DaVinci Resolve
Gunleik Groven
on Jun 15, 2012 at 11:19:36 am
Hi
I have tried to contact DaVinci support about this, but no response so far...
Issue is that sometimes, resolve seems to get stuck on one RMD and applies that to the full project.
Last time trhat happened, I was low on time and just figured this was my mistake.
This time, though, I have had time to check, and it is a resolve mess.
Here is the same clip in resolve and RCX
Resolve
http://gunleik.com/resolve_mess/Resolve.jpg
RCX
http://gunleik.com/resolve_mess/RCX.jpg
So... I did a full fresh conform after making sure the RMDs were in the R3D folders, and still all clips get the wrong settings.
Wassup?
Gunleik
Craig Harris
Re: Not reafing RMDs right when conforming...
on Jun 22, 2012 at 9:03:25 pm
Hi Gunleik,
If you want the clip to use the RMD metadata, you have to choose "CAMERA METADATA" and not "CLIP."
The Clip setting allows you to choose your own setting.
The Project setting allows you to add the same setting globally to all clips in the sequence.
The Camera Metadata setting will read the RMD file in your R3D folder.
Hopefully that helps.
Craig
