Resolve and new MacBook Pro Nvidea 650m
COW Forums : DaVinci Resolve
Christopher Adams
on Jun 11, 2012 at 7:10:00 pm
With 2 thunderbolt ports I assume 1 for high speed raid array and the other or a bmd hdsi box. Could get interesting.
Thoughts?
Nate Weaver
Re: Resolve and new MacBook Pro Nvidea 650m
on Jun 11, 2012 at 7:23:16 pm
Yes, I'm curious how this 650M would do compared to a GTX285, which is the fastest I'm used to at this point?
I looked at the specs on the Nvidia site, and the 650M seems to have a higher clock and more cores, but bandwidth is less than a 285.
Possibly for 1080p video only (+GUI, of course), the bandwidth is enough?
Nate Weaver
Director/D.P., Los Angeles
http://www.nateweaver.net
Juan Salvo
on Jun 11, 2012 at 8:28:55 pm
The 650M should perform significantly faster than the 285. In theory. I would guess comparable to a gtx470.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Christopher Adams
Re: solve and new MacBook Pro Nvidea 650m
on Jun 11, 2012 at 9:14:29 pm
Though if this is being used to work the display could this then not be used for cuda?
Juan Salvo
on Jun 11, 2012 at 9:29:30 pm
There is an integrated gpu which can run GUI, freeing 650m for CUDA.
Robert Houllahan
on Jun 11, 2012 at 9:36:27 pm
I think that is auto switching like all of the Macbook-Pro's and that you can use either the Intel 4000 GPU or the 650m but not both at the same time.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com
MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Juan Salvo
on Jun 11, 2012 at 9:51:35 pm
To display. This is the same as before with the last nvidia gpu on 17". GUI on integrated. Processing on discreet.
Jimmy Christensen
on Jun 12, 2012 at 5:41:09 am
No, the second port is used for the network adapter..
Margus Voll
on Jun 12, 2012 at 6:02:57 am
one would use 5 ghz wireless instead of thunderbolt ?
Margus
http://iconstudios.eu
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Jimmy Christensen
on Jun 12, 2012 at 6:47:32 am
Not many companies allows for connecting to the internal network through WiFi (and with good reason).
Margus Voll
on Jun 12, 2012 at 6:51:39 am
yes but we can not say it is not possible in tech sense. have usb lan then.
different question is if osx supports it.
mostly you would see laptop as on the go machine
Margus
Multibridge 2 Pro
Juan Salvo
on Jun 12, 2012 at 1:29:06 pm
Thunderbolt allows for loop through and two devices operating at full speed. So two ports = up to 4 devices at full speed.
Rick Lang
on Jun 12, 2012 at 6:42:52 pm
Juan Salvo:
"Thunderbolt allows for loop through..."
Now if only more vendors would add a second Thunderbolt port for pass through. Way too many vendors' TB implementations seem to assume their device will be at the end of the chain. That thinking certainly could constrain the purchase of TB-based devices.
Rick Lang
iMac 27” 2.8GHz i7 16GB
Rick Lang
on Jun 12, 2012 at 6:50:27 pm
Christopher, since the next generation MacBook ProbRetuna is available, I suspect Barefeats will have some benchmark results within the month. Not sure if they would specifically address Resolve performance.
Looking forward to the results some of the creatives will be posting here about their hands-on tests since I'm sure some will be buying the new laptop.
Rick Lang
andrew sableton
on Jun 12, 2012 at 8:49:29 pm
Is it really possible to use both graphics cards in a MacBook Pro in this way (1 for GUI and one for Cuda processing) ??! Has anyone actually made this work?
Juan Salvo
on Jun 12, 2012 at 9:47:43 pm
This is how it worked with resolve in the previous gen 17" MacBook pro.
andrew sableton
on Jun 13, 2012 at 12:45:49 am
So you have seen this work?
Margus Voll
on Jun 13, 2012 at 7:08:21 am
On older MacBook 17" i have used it like so.
1 one was for guy and second for gpu.
Different question is how media speed will be etc.
it should be rally possible but actual field testing is needed.
Margus
Multibridge 2 Pro
Matthew Sonnenfeld
on Jun 13, 2012 at 10:15:23 pm
What about Resolve on the Retina display and how it will pixel double any application that does not have built in support for Retina Resolution? Will this degrade the resolve interface? And keeping at the optimum resolution of the computer still has the real estate of a 1440x900 screen. How would you expect this will effect Resolve on the screen?
Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 8GB RAM
AJA IoXT
Adobe Premiere Pro CS5.5, Final Cut Pro Studio 3, Avid Media Composer 3.5.4
The College of William and Mary
