Vectorscope
COW Forums : DaVinci Resolve
stig olsen
Vectorscope
on Jun 4, 2012 at 9:09:52 am
I have a situation where its a green field and the color green exceeds 75% of the vectorscope.
Lets say I want to keep it "that green"- what is the best approach this without the need of desaturate the green?
Stig
Robert Due
Re: Vectorscope
on Jun 4, 2012 at 2:42:49 pm
Either isolate the green with a secondary key and then create an outside node OR you could use the Hue/Sat curves.
Robert Due
Editor / Colorist
INDEPENDENT EDIT
DaVinci 8.2
OSX 10.6.8
MacPro 8-core 4,1 2.93 Ghz
8GB RAM
Nvidia GT120/GTX288 (CUDA 4.0.19)
Decklink Extreme3D+
Panny BT-LH1710P/ Panny BT-LH2600W
Tangent Wave
Joseph Owens
Re: Vectorscope
on Jun 4, 2012 at 3:04:32 pm
[stig olsen] "what is the best approach this without the need of desaturate the green?"
Beyond the simple mechanics of isolating it, you are asking about "legalizing" it, as I read the question.
If the tonal impression is what you want to preserve, then you are allowed a certain overage in saturation --> But do recall that 75% is really just a target value for setting up color bars, as the YCyGMRB waveform is specifically set up to that standard so that we can reproduce them. Its like "0" VU tone.
Composite baseband usually allows up to 102IRE (luminance), and up to about 120IRE Y+C. If you do not have a good composite baseband simulation, this might be hard to measure. Its another argument for outboard scopes.
Generally, a tonal value is easiest to re-simulate (and tuck under the legalizer) by adjusting its luminance values -- In yellow and green, dropping the Y component in effect sometimes serves to "intensify" the saturation... so tweaking the saturation down a little more should serve the purpose.
jPo
You mean "Old Ben"? Ben Kenobi?
Robert Due
Re: Vectorscope
on Jun 4, 2012 at 3:18:29 pm
Yeah, what jPo said.
Robert Due
Editor / Colorist
INDEPENDENT EDIT
DaVinci 8.2
OSX 10.6.8
8GB RAM
Decklink Extreme3D+
Tangent Wave
stig olsen
Re: Vectorscope
on Jun 5, 2012 at 2:09:35 pm
Thank you guys!
