Image info missing on borders when compared to offline
COW Forums : DaVinci Resolve
Daniel Stonehouse
on May 30, 2012 at 10:55:02 pm
Rendered a Red job overnight - It seems to be missing image info on the left and right edge of frame when compared to the offline. Doesn't appear to be a scaling problem as the footage lines up perfectly.
Any ideas?
Daniel Stonehouse
Re: Image info missing on borders when compared to offline
on May 30, 2012 at 10:56:08 pm
https://dl.dropbox.com/u/2194104/offline.jpg
https://dl.dropbox.com/u/2194104/online.jpg
Kevin Cannon
on May 30, 2012 at 11:53:30 pm
If you go to Format>Input>Source Blanking OFF, does that solve it?
KC
Prehistoric Digital
Daniel Stonehouse
on Jun 5, 2012 at 2:27:56 am
It does solve the black edging - but now I am left with strange patterns of light lines near the edge of frame - that aren't present in the offline (which I believe was done using redcine -> pro res)
https://dl.dropbox.com/u/2194104/offline2.png
https://dl.dropbox.com/u/2194104/resolve2.png
Daniel Stonehouse
on Jun 5, 2012 at 3:18:10 am
After some experimentation I have found the artefacts disappear if the "Image Scaling" preference is set to "Bilinear" - The two higher quality settings "sharper" and "smoother" both exhibit different edge artefacting.
FYI I am working with 5120 x 2060 RED footage, in a 2560 x 1080 timeline, with Output Format set to 1920 x 1080 (so outputting 1080 with black bars).
Interested if anyone else has experienced similar problems - would love to know if its a bug, a known issue, or a problem specific to my workflow?
