Appending nodes simultaineously to multiple clips
COW Forums : DaVinci Resolve
John Pilgrim
on May 30, 2012 at 4:01:10 pm
Hi all,
Quick question:
What are the best ways to append a set of additional nodes simultaineously to MULTIPLE clips that already have nodes?
I have my sequence graded and now need to add tints on a scene-by-scene basis and don't want to have to go clip-by-clip within each scene.
In Apple Color one could select multiple clips and drag a Secondary or a Primary Out onto the selected clips and all the selected clips would receive that secondary or PO.
Looking for a similar functionality in Resolve.
John
Joseph Owens
Re: Appending nodes simultaineously to multiple clips
on May 30, 2012 at 4:11:12 pm
Group.
jPo
You mean "Old Ben"? Ben Kenobi?
John Pilgrim
on May 30, 2012 at 4:16:44 pm
Thank you Joseph!
I will RTFM re "group". (Sometimes it's just a matter of knowing the correct terminology.)
I assume appending nodes to grouped clips will not overwrite the existing nodes on the individual clips.
Joseph Owens
on May 30, 2012 at 4:24:56 pm
[John Pilgrim] "I assume "
You know the ass/u /me breakdown. I am not in the practice of using groups, so I don't know.
It might be slow, but I prefer to call up the node graph and paste a common node where I need to, if there is a requirement to "add a layer" to a scene. I couldn't honestly tell you if the grade "unifies" when you "group" clips, and it would be interesting to know if the "overall" node might have different effects within a clip if there is a different hierarchy in some of the corrections.
jPo
Conor Bowes
on May 31, 2012 at 4:40:34 am
I would recommend doing this via the track graph and animation on/off at the start/end of each scene.
I grade 5 30 minute television episodes a week (using groups) and unless they are grouped before the grade and have exactly the same grade on them we have had many issues with it overwriting nodes in the tree on random clips.
It becomes very difficult and unwieldy to do this and entire scene changes I have found it much easier to do this via the track
Conor Bowes
Colour Grader
http://www.thaumaturgy.com.au
Rohit Gupta
on May 31, 2012 at 7:51:32 am
There is a node ripple function which lets you ripple the current node to a range a clips by appending the node to the end of the graphs. This is currently possible only on the Resolve Control Surface though.
Sascha Haber
on May 31, 2012 at 10:06:15 am
And when will we get this very useful function on the Element or Wave ?
Or the Menu ?
A slice of color...
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
ICA Instructor
http://www.icolorist.com/Sascha.html
Gabriele Turchi
on May 31, 2012 at 2:12:57 pm
hi rohit ,
how do i use that function on the resolve panel?
is a combination ? like -,+ripplevalue ?
thanks
g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX470
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Ultrascope
Rohit Gupta
on May 31, 2012 at 4:25:33 pm
I think it is -,+ Shift Up + Ripple, or maybe Shift Down + Ripple. Instead of -,+, you can of course use, , + Ripple
Reuben Fink
on Mar 31, 2014 at 6:18:17 pm
Do you know if this is now possible without the control service in Davinci 10?
OSX 10.8.5
Equipment: 2.8 ghz 8 core Intal Mac Pro 3,1 Early 2008, 20 gig of ram
Aps: Adobe CC , FCP Suite, Avid Media Composer
