Yellow LUTS
COW Forums : DaVinci Resolve
Zack Marchinsky
Yellow LUTS
on May 21, 2012 at 6:48:11 pm
Doing some onset LUT generating with Davinci Resolve Lite. Just loaded some footage we shot with a Canon XF105 which saves files in .MXF. For some reason when I go to check the LUT i created to make sure it works, it's making my grade turn all yellow instead of adding the look I want. Any thoughts?
Dan Moran
Re: Yellow LUTS
on May 22, 2012 at 8:35:14 am
Hey Zack,
Are you using the trim LUT file?
This is in Libary/Application Support/Blackmagic Design/DaVinci Resolve and it is a DPX file.
You must have your playhead on this file when you hit Generate Lut for the generation process to work correctly.
In v9 this will be simplified to a right click on the VSR's on the timline.
Hope this helps!
Dan
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA
Zack Marchinsky
Re: Yellow LUTS
on May 22, 2012 at 2:43:28 pm
Yes I am using it. I have no problem generating LUTS for my ALEXA footage. But the Canon XF105 .MXF footage still gives me an issue.
Confusing because Davinci will bring in the files and let me grade them. Is there a possible setting I might have activated/turned off?
