Resolve on Win - Performance Lack with Waveform-/Vectorscope-Monitors on
COW Forums : DaVinci Resolve
Alexander Falk
on May 16, 2012 at 6:55:34 am
Hello,
i started Resolve on Win with one Quadro5000 for GUI and GPU. Works okay.
I add a Quadro400 for the GUI, to use the quadro5000 for GPU-only. If i then turn on Scopes it drops down to 2-3 fps playback without any corrections applied. If i close all scopes it runs with 25fps.
I then add a Quadro4000 for the GUI, but it was the same, which doesn't make a sense to me!
Slot configuration is correct. All drivers and setup files as recommended in the configuration guide.
If i run Quadro5000-only it runs 25fps with scopes and corrections applied. Really doesn't make any sense to me!
Any clues?
