Don't update to 10.7.4 yet if running GTX5xx cards
COW Forums : DaVinci Resolve
David Pirinelli
on May 10, 2012 at 1:07:05 am
There should be a new "Web Driver" posted by Nvidia shortly, don't update before you hear about this and CUDA all working together.
Clark Bierbaum
Re: Don't update to 10.7.4 yet if running GTX5xx cards
on May 10, 2012 at 1:33:40 am
Thanks for the heads up, David!
BTW - If you need a card David is the MAN. Helped with some issues and now my system ROCKS!
Thanks Again!
Clark
Clark Bierbaum
Colorist, Contractor, Realtor
Charlotte, NC
Juan Salvo
on May 10, 2012 at 1:49:32 am
Wonder if well get support for 600s? Thanks for heads up David.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Victor Hammer
on May 10, 2012 at 8:03:44 am
I already did and now I have a black screen! how do I go back to the earlier version!
Thank you
David Pirinelli
on May 10, 2012 at 8:44:58 am
Give me a few minutes, I am going to try to fix the driver kext.
OSX 10.7.4 breaks the "MAGIC " support.
I have a feeling that Nvidia will release new drivers for 10.7.4 soon, but until then I will figure out and post a fix.
EDIT: OK, here is a quick fix. This will enable the driver to include GTX570 and GTX580.
I will do one for GTX560 later on.
If you were using the ""self init" feature, you will also need to install ATY_Init from Netkas.
If you had one of our EFI cards, this should do it by itself.
You will need to use Kextdrop or Kexthelper to install this once you unzip it.
4109_nvdagf100hal.kext.zip
If you are using an EFI card, you will have one screen still functional to "see" from while you install this. If you were using the "Magic" feature, the card will be black as night until you install this fixed next AND ATY_Init.
If you were using Magic Drivers to run a GTX4xx card, you don't need this fixed kext, just ATY_Init.
David Pirinelli
Nvidia releases 10.7.4 update to "fix" Apple's 10.7.4
on May 10, 2012 at 5:16:35 pm
http://www.nvidia.com/object/macosx-270.00.00f06-driver.html?ClickID=bmumuz...
Esteban Aguilera
Re: Nvidia releases 10.7.4 update to "fix" Apple's 10.7.4
on May 11, 2012 at 8:45:41 pm
Anyone has tested, is very curious because 10.7.4 in mbp runs super fast, first time it does with lion.
with the last nvidia drivers is again everything working ok ?
Di Davinci Resolve Colorist
Ralf Kleinermanns
on May 13, 2012 at 2:00:18 pm
Even with Nvidias latest driver update 10.7.4 broke OpenCL support for Nvidia cards.
I downgraded to 10.7.3 from TimeMachine backup -> Apple mail stuck while (forced) re-import of my mails, so I had to rebuild my 10.7.4 system from the backup I did before downgrading. Thanks Apple: great user experience! :(
Sascha Haber
on May 14, 2012 at 11:06:31 am
Yep, they are getting better and better for pro users .
A slice of color...
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
ICA Instructor
http://www.icolorist.com/Sascha.html
David Pirinelli
on May 14, 2012 at 8:50:28 pm
The OpenCl fix is pretty much same as before.
On front page of Netkas.org
Robert Due
on Feb 1, 2013 at 4:19:03 pm
David,
I have a GTX 580 from Macvidcards and I am wondering if I need to update the NVIDIA driver or not.
Would it be a good idea to install the
NVIDIA driver version: 295.00.05f02
on OS X 10.7.5?
I don't want to screw anything up.
Thanks in advance
Robert Due
Editor / Colorist
INDEPENDENT EDIT
DaVinci 9.0.3
OSX 10.7.5
MacPro 8-core 4,1 2.93 Ghz
8GB RAM
Nvidia GT120/GTX570 (CUDA 5.0.36)
Decklink Extreme3D+
Panny BT-LH1710P/ Panny BT-LH2600W
Tangent Wave
Jon Michael Puntervold
on May 16, 2012 at 8:47:07 pm
So does the new nVidia drivers get back the same magic functionality as in OSX 10.7.3?
I've got a new Mac Pro waiting to get set-up, and a GTX 580 in the mail...
BTW: How is it with the 6-pin mini power connector to 8-pin plug. Any suggestions for a nice cable?
Rohit Gupta
on May 16, 2012 at 11:20:44 pm
The PC version of GTX 570/580 both seem to work with the new driver in 10.7.4. Same as 10.7.3.
Graham Hutchins
on May 17, 2012 at 3:41:56 am
Hi Rohit,
Can you tell me if you're getting a boot screen (Apple logo) when you boot up under 10.4.7 with the new Nvidia driver?
Thanks.
OSX 10.7.3
Adobe CS6
FC Studio 3
Octo 2.26GB MacPro, 32 GB RAM
Juan Salvo
on May 17, 2012 at 3:52:29 am
If you're not using an EFId card (from macvidcards) and your monitor is connected to the 570/580 card, you will not see a boot screen. Only work on cards running efi firmware.
mark wagner
on Jun 5, 2012 at 2:20:25 pm
any idea how i can make this work with a GTX470?
Mark Wagner
Colorado | Berlin
