Pink / magenta blinking
COW Forums : DaVinci Resolve
stig olsen
on May 5, 2012 at 9:25:43 pm
Im working on a commercial shot on Red Epic.
Suddenly out of nowhere the clips on the timeline started blinking pink/magenta. I can see it when I play the clips, but also on the thumbnails. I have never experienced this before on any red footage.
The color science is YRGB.
When changing from lets say "redlogfilm" to something else, and back - everything is going back to normal.
Any idea?
Stig
Ola Haldor Voll
Re: Pink / magenta blinking
on May 6, 2012 at 8:23:00 am
For all it's worth - what's your hardware setup?
stig olsen
on May 6, 2012 at 5:07:28 pm
The setup is the same as before, declink, a couple of graphic cards and a red rocket in the recommended slots.
The only difference is that I did upgrade to Lion and the latest davinci patch with the latest drivers.
Really noone that have experienced this magenta/pink blinking?
Stig
Juan Salvo
on May 6, 2012 at 5:37:08 pm
Nope, I haven't seem this. What camera is this from? Whats the firmware. I've seen funky issues from certain camera firmware combos. Did you update the rocket firmware? Could be a rocket issue. I've seen them fail.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Margus Voll
on May 6, 2012 at 5:43:35 pm
simple way would be to remove rocket and see.
my first guess would also be rocket.
Margus
http://iconstudios.eu
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Jamie Franklin
on May 8, 2012 at 3:23:22 am
Go into System Settings, Blackmagic Resolve driver, cycle on and off or turn off 444 and it should revert back.
stig olsen
on May 8, 2012 at 6:45:43 pm
Thank you guys, I will try that.
stig olsen
on May 9, 2012 at 9:23:25 am
Hi Jamie,
I cant find a way to cycle on/off the black magic resolve driver and turn off 444, where to do that?
Jamie Franklin
on May 10, 2012 at 8:04:36 pm
System *Preferences*, not settings, (sorry) window there should be a driver at the bottom "Blackmagic Design" with the yellow squares...
If I cycle "Use 4:4:4 SDI on video" it usually gets rid of the 444 signal that gives you those colors.
stig olsen
on May 16, 2012 at 9:19:29 pm
Thank you Jamie, now its gone!
