RED file not rendering properly
COW Forums : DaVinci Resolve
Chad Smith
on May 2, 2012 at 9:38:15 pm
Working with Resolve Lite 8.2.1 Grading a feature shot on RED ONE. For some reason on file will not render with proper in and out point and also is not taking the grade. I tried making a local version of the correction and tried to render just that clip but Resolve still wants to render the entire clip with no grade. Is there a way for me to get it to work? Hmmm.
brandon thomas
Re: RED file not rendering properly
on May 3, 2012 at 2:46:07 am
Are you grading from the raw? What's the name of the file?
Chad Smith
on May 3, 2012 at 3:05:52 pm
Hi Brandon - Yes it is an R3D file that has variable speed adjustment. Perhaps that is the issue? File name is A087_C006_082420
thanks
Chris Martin
on May 4, 2012 at 3:57:23 pm
Yes probably a limitation of working with the live R3D. I know you can't do render cache with R3D either. Try rendering it out at 1:1 speed. Then recreate speed effect back in your NLE. Better workflow anyway to color at 1:1 speed in Resolve anyway...
