Video files look corrupted
COW Forums : DaVinci Resolve
Michael Sanders
on May 1, 2012 at 6:42:53 pm
Hi All,
When I load a XML into Resove Lite 8.2 sometimes, some clips look like they are corrupt. (Either lower half is green or two magenta pics side by side, or similar sort of thing). All the clips look fine in FCP X and I've now had it happen with XDcam HD and Canon MXF files.
Am running lite on a pre thunderbolt i7 2.8GHz Macbook Pro with 8Gb. Media is on a G-TECH 2TB RAID3 connected via a Tempo Pro esata E34 card.
Any ideas welcome
Michael Sanders
London Based DP/Editor
Ola Haldor Voll
Re: Video files look corrupted
on May 1, 2012 at 7:54:24 pm
I've had a ton of issues with NLE generated XDCAM files. Magenta/green blocks all over the place, but looks fine in any NLE. XDCAM files directly from camera are no problem.
I contacted DaVinci support and sent them the file for them to investigate. I suggest you do the same.
Ola Haldor Voll
on May 5, 2012 at 7:17:23 am
I'm pleased to say 8.2.1 beta fixed the problem for me. Hopefully it does for you too. :)
