8.2.1 cinemaDNG question
COW Forums : DaVinci Resolve
John Christoforu
on Apr 17, 2012 at 2:47:06 pm
Good afternoon, much anticipated 8.2.1 version that supports cinemaDNG
footage is finally here. Just created a new project and imported Ikonoskop DNG files.
Went to the cinemaDNG window changed the parameters and nothing seems to be different,
material looks the same as the older version and clipped magenta highlights are still there.
Any thoughts…
Thank you!
John
Javier Sanchez
Re: 8.2.1 cinemaDNG question
on Apr 18, 2012 at 12:53:42 am
I have same clipping magenta on other materials seems an error of data range monitoring.
Craig Campbell
on Apr 30, 2012 at 2:15:14 pm
Hello,
If you set the Cinema DNG settings in config>source nothing will happen.
If you right click the clip in the timeline and click edit Cinema DNG settings you can then manipulate the settings for the clip, if you select project it will add the settings you changed in config>source as well as individual clips and metadata from the camera.
Hope that helps
Craig Campbell
on Apr 30, 2012 at 2:17:16 pm
Sorry I also meant you can also change the settings for the individual clips or take the metadata from the camera
John Christoforu
on Apr 30, 2012 at 3:27:05 pm
You can't imagine how helpful your instructions was, I can now shoot normal instead of under exposing my footage 1.5 stop fearing magenta clipped highlights. One again, you help really appreciated!
Best regards John
