Graded at improper frame size, can I copy over grades?
COW Forums : DaVinci Resolve
David Powell
on Apr 15, 2012 at 12:01:35 am
So I rendered a 720p movie to prores HQ that went to 1920x1080, didn't realize I had done this t'ill after I finished grading and rendered out the final movie. This was a flat movie grade. I'm wondering is there a way I can bring in the proper size movie and copy the grades shot by shot? Or export a grade edl or sorts and bring it on top of the proper movie?
Ola Haldor Voll
Re: Graded at improper frame size, can I copy over grades?
on Apr 15, 2012 at 12:51:55 am
Do I understand you correct?
- You received a single QT file
- Scene Cut or EDL to split at edit points
In theory, you should be able to just replace the file. Give the old one a new name and give the new 1080p file the old file name of the 720p file.
Resolve won't know what happened. Go to Config set 1920x1080 as the resolution.
David Powell
on Apr 15, 2012 at 1:27:59 am
excellent, so I can put the highres file in under the first files name, open the project and re-render at 1920x1080. I'm hoping that will work. Thanks a bunch.
Ola Haldor Voll
on Apr 15, 2012 at 9:39:45 am
In THEORY, it should work, as long as the edit is exactly the same and the filename is the same.
Arthur Dobbe
on Apr 15, 2012 at 9:27:55 am
Yes, using the ColorTrace function you can copy the grades shot by shot. See manual for 'ColorTrace'.
Eric Johnson
on Apr 15, 2012 at 8:59:45 pm
The only big issue could be any shapes.... Aren't those based on the timeline size that they were created in?
Ola Haldor Voll
on Apr 15, 2012 at 9:44:16 pm
If he resizes the timeline from 720p to 1080p, it wouldn't be a problem as far as I know. Shapes should resize accordingly.
