After Effects to Davinci
COW Forums : DaVinci Resolve
David Stretz
on Mar 30, 2012 at 12:51:28 pm
I took a few of my original clips & threw them into After Effects so I could use the "Neat Video" plug-in for noise removal. I rendered the AE files into a folder as Quicktimes.
When I look for the files in Davinci they are no where to be found, every other file is there.
brandon thomas
Re: After Effects to Davinci
on Mar 30, 2012 at 3:17:20 pm
make sure the files have the '.mov' extension, and tat you're rendering out of after effects to a supported codec.
Erik Lindahl
on Mar 31, 2012 at 10:35:25 pm
Perhaps also make sure timecode on your output-files from AE match the input.
Jay Bloomfield
on Apr 1, 2012 at 12:14:42 am
Just because a file has a MOV extension doesn't mean Resolve will display it in the list of files, even though it actually exists in that folder. The file must be in both a wrapper and encoded with a codec that Resolve will read. For example, Resolve just ignores DNxHD files with a MOV extension. It reads many other MOV files (Red, Cineform, H.264, etc.) with no problem. It will read DNxHD files in an MXF wrapper.
David Stretz
on Apr 5, 2012 at 6:21:59 pm
how can you put something in an MXF Wrapper?
Juan Salvo
on Apr 5, 2012 at 6:56:36 pm
Bring it in to Avid. Consolidate it to MXF.
Additional twist is that there are different flavors of mxf.
Sony's MXF is different than Avids MXF.
