DCI Cinema Suite for Final Touch
COW Forums : DaVinci Resolve
Hans Vogel
on Mar 30, 2012 at 7:20:10 am
Hi there
Does anybody knows a DaVinci DCI suite to rent in europe?
Here is our situation:
Until now we mainly graded tv-features and commercials.
Therfor we worked on our monitor system.
One of our clients now asked us to do the grading and mastering for a cinema feature.
The DP likes to work in a DCI Suite, but he would be fine to do the pregrade and effects (5-10days) in our regular suite to go to a DCI Suite (we bring our colorist) to do the final touch (3-5 days) afterwards.
There is not such a suite to rent in Switzerland. Does anybody something like that in Europe?
Kind regards
HC
Robin Erard
Re: DCI Cinema Suite for Final Touch
on Mar 30, 2012 at 9:51:14 am
Hello,
We are in Switzerland. We graded several films for cinema DCP. But we don't work on DCI projector, we have a REC709 callibrated projector.
We generate DCP here and test them in a cinema theater close to our office.
our website : http://www.gradingroom.org
Best
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.ch
Hans Vogel
on Mar 30, 2012 at 9:58:47 am
Hi Robin. Thanks for the quick response.
We have a similar suite like you. But we need a bigger screen.
Kind regards
HC
Robin Erard
on Mar 30, 2012 at 10:02:47 am
Hello,
Yes our screen is not so big, 2m X 1m.
You could try at EGLI in Zürich but not sure they have a bigger screen. Or maybe in Freestudio in Geneva. But it will be expensive.
Best
Robin
Hans Vogel
on Mar 30, 2012 at 10:08:31 am
Egli runs a Baselight Suite. We need a Davinci suite so we can bring the raw material and the project.
What system runs at Freestudio? Do you know that?
cheers
HC
Dan Moran
on Mar 30, 2012 at 10:24:07 am
If you can't find a DaVinci suite why don't you go down the old school route of a "test print" ?
When I grade for 35mm release we render out some of the key / difficult scenes. Normally a couple of minutes of film and then when the lab has processed go down to our local cinema and watch it in context.
You can take a few notes and compare what you expected to what you get.
RGB to XYZ luts are great anyway so you should have no issues
Works for me!
Hope this helps.
D
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA
Hans Vogel
on Mar 30, 2012 at 10:30:44 am
Hi Dan. Thanks for the hint.
I was a little bit impresices. Sorry. The final result will be DCP only.
We recommended to go 2 or 3 times to a DCI cinema to check different kind of footage (outside/inside/day/night etc.) during the process. But that is not good enough for the DP.
He want's to to the final on a big screen / theater.
So if anybody knows such a facility in europe running Davinci Resolve, would help a lot.
Thanks.
Dan Moran
on Mar 30, 2012 at 10:35:58 am
If he's not happy make him pay for the rental ;)
I'm not sure of many places that have such a high spec and are open for rental i'm afraid.
Just another alternative idea, I was grading a music video as part of Den Lennie and James Tonkin's Music Video Masterclass 2011 and we needed a cinema to grade in due to the amount of students.
The best option we found was to bring our DaVinci system into a cinema and connect via 3g SDI. Was the cheapest option by far and only took about an hour to get set up in the morning.
Sorry I only have alternative ideas but I don't know many DCP compliant studios!
D
Dan Moran
Hans Vogel
on Mar 30, 2012 at 11:00:00 am
@Dan: We already thought about going to a DCI Cinema. It's not a bad idea and I would definitely go this way with my own project. I think the DP is just used to big Lustre or Baselight suites.....
Ola Haldor Voll
on Mar 30, 2012 at 10:44:26 am
Hey, when do you need this? I'm in Trondheim, Norway, and have a Resolve system on a Mac Pro (only one GPU at the moment - more to come). I've got access to a 8m wide screen in a theatre with ~100 seats and a Christie CP2220 Projector. The projector must be fed with a Dual-Link 4:4:4 XYZ signal - which is applied as a Display LUT in Resolve. Essentially - what you see is what you get.
If you can, I'd suggest you consider renting or purchasing an Autocue monitor (or similar..). In my experience, when the monitor is set right - it comes really, really close to the experience of what you'll see in terms of black levels and saturation in the theatre, so in the end it should only be minor adjustments.
Hans Vogel
on Mar 30, 2012 at 11:02:48 am
@ola: Wow. Your setup sounds great! Maybe I can convince them to travel to Trondheim in November. At least it's dark outside, so not a big difference to the grading suite :-)
It's off topic. But how is you experience with the autocue? Does it come with any calibration tool?
Cheers
HC
Ola Haldor Voll
on Mar 30, 2012 at 11:25:06 am
Within November I'm sure I've upgraded to multiple GPUs. I'm on the JL Cooper panel for now if it matters any.
On the off-topic; I'm very, very happy with the Autocue. I can adjust about anything and it has a D-cine color space with option to select 6302 Kelvin (which I'm told is the same as the Christie bulb is) along with gamma such as 2.2, 2.35, 2.4, 2.6 and probably a few more steps.
I've set up my monitor with two presets. One for cinema with DL SDI 4:4:4 D-Cine and one for SDI 4:2:2 RGB. Makes it quick to jump from one preset to another if you're on different projects at the same time.
There's no automatic calibration tools, but you can produce black to white in a range of 8-10 steps or so, and red, green, blue screens. According to Russel at Autocue, you connect say, an X-rite on the screen and go through the different shades of gray and read the values in the calibration app on the computer. Then you can adjust the settings in the monitor to the correct values.
dermot shane
on Mar 30, 2012 at 11:35:18 am
maybe the Dolby ref mon is another answer?
not big, but it is accurate
d
Hans Vogel
on Mar 30, 2012 at 2:43:00 pm
What price range are we talking about?
Ola Haldor Voll
on Mar 30, 2012 at 8:41:42 pm
We're talking tens of thousands of dollars.
Hans Vogel
on Mar 30, 2012 at 2:43:44 pm
I think about one of those monitors, if we are really gonna do a DCI grading.
Thanks for the the support.
HC
Simon Jaquemet
on Mar 31, 2012 at 7:34:53 am
Hi
They seem to have a DCI projector:
http://www.suite16.ch/
I don't know them but it looks impressive. Don't know if they work with Davinci.
There's also Elefant Studios:
http://www.elefantstudios.ch/
The have a Baselight. I know they did a DCP lately. Maybe they can also provide a Davinci in the grading room.
Cheers
peszteres lászló
on Mar 31, 2012 at 5:15:52 pm
In Budapest, http://www.origofilmgroup.com/ 2-3 large projector is located there, DCP theater 10-12m
Hans Vogel
on Apr 2, 2012 at 7:15:06 am
közönöm sepem laszlo.
Do you know what system they are running at Origon? Baselight?
peszteres lászló
on Apr 3, 2012 at 4:58:27 am
Yes, it is Baselight 8, however, the DCP projector room can be rented separately. I can give you a Davinci-Resolve 8,2 complete system......
regards
Hans Vogel
on Apr 4, 2012 at 12:08:21 pm
Hi Laszlo
can you send me your emailadresse to herein@planbfilm.ch?
thanks
hc
