GTX 570 properties under OSX 10.7.3
COW Forums : DaVinci Resolve
Knut Jansohn
on Mar 29, 2012 at 8:37:58 am
I've now a 570 (evga hd, 2.5 gb) implemented in my MP 4.1 (newest drivers).
It gives a satisfactory speed under resolve BUT the systemprofiler doesn't show anything for pci-bus! Instead an errormessage occours :(
Is that the price for mounting a pc-card under OSX?
I wonder if anyone has mounted a pc-card in MP and has a healthier system?
Do I miss something?
Regards
K.
Sascha Haber
Re: GTX 570 properties under OSX 10.7.3
on Mar 29, 2012 at 9:35:09 am
you miss Lion
A slice of color...
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
ICA Instructor
http://www.icolorist.com/Sascha.html
Dan Moran
on Mar 29, 2012 at 9:56:01 am
My cards show up as normal. All PC cards.
Have you installed the latest Nvidia driver from their website?
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA
Rohit Gupta
on Mar 29, 2012 at 10:05:23 am
The error is under the PCI Cards section, not Graphics/Displays. It happens with the Q4000/Mac I think. Nothing to worry about.
Knut Jansohn
on Mar 29, 2012 at 10:32:09 am
Thanks guys!
Yes the error occours only in the pci-bus section.
The card is displayed right in the grafics section as gtx 570 :)
Well that reassured me, but a little doubt stays that everything is fine with the pci-bus (extreme 3d+, esata).
Sascha, what do you mean (miss lion)?
K.
Knut Jansohn
on Mar 29, 2012 at 11:04:02 am
[Rohit Gupta] "It happens with the Q4000/Mac I think"
That means it will occour with regular Q4000 (mac-version) too?
And seems to be related to the driver?
Margus Voll
on Mar 29, 2012 at 1:17:45 pm
Where do you see this error ?
I looked at my gonfig and did not see any. I have mac 4000 and 470
Margus
http://iconstudios.eu
Knut Jansohn
on Mar 29, 2012 at 2:36:21 pm
Error appears: About this mac / more infos / pci cards
Normaly there are all pci devices listed (including grafic cards), if drivers installed etc etc
With mounting the 570 it says something like 'an error occours' and nothing else is listed.
But everything seems to run well.
Only the message...
David Pirinelli
on Mar 29, 2012 at 7:55:51 pm
This is due to the self-init function of the drivers.
Using ATY_Init in other oS versions gives same bug.
Not sure why, just how it is. Only EFI inited cards show up properly here.
Most of the self-inited cards are running at PCIE 1.0 Spec of 2.5 GT/s but it is hard to verify due to "Error" in PCI cards section.
Use CUDA-Z and your Single Precision number should be 1100-1300 for a 570 and your device to device pinned will be around 2900. EFI inited cards will show 5600-5900 for device to device pinned.
Gabriele Turchi
on Mar 30, 2012 at 4:54:37 am
hi david
i thought the GT/s number is listed in the graphic card tab (not PCI card)
i can see that my 470 are listed @ 5GT/s in system proprieties graphic card tab .. (the PCI tab on my system is not working at all because i have the cubix)
g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
David Pirinelli
on Mar 30, 2012 at 5:41:54 am
i have never seen the number there.
Are you certain?
Fred Ricci
on Mar 30, 2012 at 6:11:20 pm
Hi there Knut
What do mean by satisfactory speed? How does it compare to the gtx285?
NEHALEM OCTO 2,26
GT 120
GTX 285
8 Giga RAM
SOFT RAID 8 Tera
Wave
Eizo 243 + Hdlink displayport
DAV, COLOR, FINAL CUT AND MEDIA COMP
Knut Jansohn
on Mar 31, 2012 at 12:46:44 pm
[Fred Ricci] "How does it compare to the gtx285?"
Hi Fred,
as I hoped for, it tops the flashed 470 :)
http://forums.creativecow.net/readpost/277/16040
So for my money it's a very reasonable deal (around 300€) even though it will hopefully replaced by 680 this year.
K.
Fred Ricci
on Apr 7, 2012 at 11:26:34 am
NEHALEM OCTO 2,26
GT 120
GTX 285
8 Giga RAM
SOFT RAID 8 Tera
Wave
