MacPro + GTX260 : Intensity Pro Killed the GTX : anyone else?
COW Forums : DaVinci Resolve
Gabriele Turchi
on Mar 21, 2012 at 12:50:04 am
Hi , i am wondering if anyone else had this issue i am having :
just installed Resolve @ home (testing etc..)
i have macPro 2009 8 core , GT120 + GTX260 (resolve report 1GPU (processing power) so all good
today i have installed the intensity Pro , but as soon as i start the Mac Pro the fan of the GTX spinning at max speed and the system won't see the GTX anymore ...
tried swapping slots ...same issue , if i remove the intensity : the GTX show up again ..
But the intensity card seems working correctly ...
anyone else ?
maybe bad card ?
thanks
g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Gabriele Turchi
Re: MacPro + GTX260 : Intensity Pro Killed the GTX : anyone else?
on Mar 21, 2012 at 3:54:44 am
FYI ,
problem solved,
after swapping cards around in the slots (still the issue) i plugged the HDMI cable to the Intensity , and the issue disappear , fan of the GTX stopped spinning and the GTX showed up again ,
i assume was a static electric thing that plugging the HDMI cable went away ..
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Esteban Aguilera
on Mar 21, 2012 at 9:54:57 am
Try using the debug text, with the 3 lines.
Look at the forum with the text "debug"
Di Davinci Resolve Colorist
Gabriele Turchi
on Mar 21, 2012 at 2:37:56 pm
Eastban ,
it was an electrical issue between the card and the motherboard ...the GTZ was going crazy the very second i turned on the mac pro ...
nothing to do with resolve software ...
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Peter LeWetzel
on Aug 11, 2012 at 2:15:35 pm
Hi Gabriele,
did you solve the problem between your GTX260 and the intensity card? And how? I´m very curious, because I have almost the same thing: With the BMD card my GTX 285 is offline... I could make my configuration work sometimes by switching on the monitors in a particular order, but it´s not a solution at all.
Thanks a lot for any help!
