Standard Candle v82
COW Forums : DaVinci Resolve
Margus Voll
Standard Candle v82
on Mar 20, 2012 at 12:02:34 pm
Hi.
I just did re upload Standard Candle test that Sascha made.
I just exported from V8.2
Feel free to download:
http://www.iconstudios.eu/Standard Candle v82.resolve.tar.gz
Please report your results if you have new exiting setups with gpus.
Margus
http://iconstudios.eu
Knut Jansohn
Re: Standard Candle v82
on Mar 20, 2012 at 7:30:43 pm
Hi Margus,
nice, but due to the blanks it seems that the link doesn't work?
Regards
K
Margus Voll
on Mar 20, 2012 at 8:09:45 pm
I will put up both version then.
For me on Chrome on mac it worked perfectly if you copy pasted the whole url.
Here is with no spaces.
http://www.iconstudios.eu/Standard_Candle_v82.resolve.tar.gz
Look if this seems better?
Margus
Benoit Cote
on Mar 21, 2012 at 6:24:42 pm
Thanks Margus for re-posting that file !
Here are my results (Cubix desktop4 with 3 quadro 4000 gpus) :
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 19 fps
V5 NR 4 : 24 fps
V6 NR 4 : 14 fps
V7 NR 4 : 16 fps
V8 NR 4 : 4 fps
disappointment
Benoit Cote
Colorist
http://www.lacavalerie.ca
DaVinci 8.0.1 OSX 10.6.8
MacPro 5.1 2x2,6 12GB
RAID5 36TB MetaSAN
Quadro 4000 x4 Cubix Desktop 4
Extreme 3D+ Wave
Margus Voll
on Mar 21, 2012 at 6:37:44 pm
Hi.
I have 4000 as gui gpu and 470 as resolve gpu and i get something like this:
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 22 fps
V4 12 nodes : 12 fps
V5 NR 4 : 24 fps
V6 NR 4 : 19 fps
V7 NR 4 : 9 fps
V8 NR 4 : 2 fps
I tested on 10.7.3 and with 6 gig ram. Mac Pro 5,1 dual 6 core @ 2.93 ghz.
Sasha got a bit better results but i think it is something to do with my ram being only 6 gigs.
Generally my system is the same he does but he got a bit better results.
You probably should change those 4000 as they are not as fast as one would think.
You probably have seen here daily about 5xx series and probably 6xx series gpu's.
Margus
Sascha Haber
on Mar 21, 2012 at 6:58:39 pm
I am having the same numbers with ONE 470 in the machine.
Sorry to tell...
A slice of color...
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2x2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+
ICA Instructor
http://www.icolorist.com/Sascha.html
Benoit Cote
on Mar 21, 2012 at 7:23:26 pm
Don't be sorry Sascha, those numbers are just THE good reason to get the 3x gtx680 next friday !!
From what I can see from previous post, there is not much difference between a double and a triple quadro 4000 setup... I knew our setup wasn't that powerful but I thought the third 4000 was making a bigger difference.
No particular problem running those flashed 470 card?
Also, with the recent break in nvidia support (10.7.4 beta update), would you buy a pc gtx580 or 680 anyway or you would stick with flashed cards?
Benoit Cote
Colorist
DaVinci 8.2 OSX 10.6.8
RAID5 36TB MetaSAN
Extreme 3D+ Wave
Aaron Hayden
on Mar 22, 2012 at 2:02:43 am
Id like to run this on my windows box with 3 gtx 580's and a quadro 4000, but i can't get it to import into resolve.
Gives me the error "failed to open archive!"
Is it not possible to open mac resolve projects on a windows resolve box?
Aaron Hayden
Colorist
Gurney Productions
Rohit Gupta
on Mar 22, 2012 at 5:23:39 am
Are you exporting in zip format?
Margus Voll
on Mar 22, 2012 at 8:53:54 am
I just made zip version also:
http://www.iconstudios.eu/Standard_Candle_v82.resolve.zip
See if it helps?
Margus
Aaron Hayden
on Mar 22, 2012 at 10:37:45 pm
Now it works, Thanks!
Here are my results.
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 24 fps
V5 NR 4 : 24 fps
V6 NR 4 : 24 fps
V7 NR 4 : 24 fps
V8 NR 4 : 12 fps
System info:
SuperMicro 7046gt-trf
2 x xeon X5690 3.47 GHZ
24 gigs of ram
1 quadro 4000 for gui
3 gtx 580 for gpu
Aaron Hayden
Colorist
Gurney Productions
Colin Travers
on Mar 23, 2012 at 4:05:38 am
Just to be sure here, all i did was import the project and hit play for each version..not adjusting any project or playback settings or is there something i need to know in order to do this test correctly?
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 12.5 fps
V5 NR 4 : 24 fps
V6 NR 4 : 19 fps
V7 NR 4 : 10 fps
V8 NR 4 : 3 fps
I plan to upgrade to a 580 or 680 in order to maximize performance on my MacPro and allow for rendering beyond 2k as well which is not possible because of the low ram on my current 470.
Thank you for posting this up!
MacPro 12-core 5,1 2.66 Ghz
32GB RAM
RAID0 8TB Internal
Nvidia GT120/GTX470
BMD Extreme3D
HDlink3D DisplayPort
Dreamcolor/Panny VT25
Tangent Wave / Wacom
Margus Voll
on Mar 23, 2012 at 7:20:12 am
>Just to be sure here, all i did was import the project and hit play for each version..not adjusting any >project or playback settings or is there something i need to know in order to do this test correctly?
no this is as it is intended. no adjustments.
I'm thinking of hd or 4k candle as some people have to fast gpu configs :)
I will see if i get material what i can distribute.
Margus
Sascha Haber
on Mar 23, 2012 at 7:55:46 am
Hey Magnus,
The idea is not to use 4K material but to make a 4K project and do the GPU work on 4K
playing the media is too dependent on other criteria.
But I agree, some 3x580 might want to double the amount of nodes ;)
Thats all it does actually, give you more of them , it wont play faster.
A slice of color...
RAID0 8TB
Extreme 3D+
ICA Instructor
Margus Voll
on Mar 23, 2012 at 10:57:15 am
Yep totally agree.
My point was just to not have those insane 120 node results coming up with beefy configs
like with 3d mark etc.
Margus
Dan Moran
on Mar 23, 2012 at 2:33:14 pm
Hi Guys,
Just testing out my system :
12 Core Mac Pro
3x580's
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V5 NR 4 : 24 fps
V6 NR 3 : 24 fps
V7 NR 2 : 24 fps
V8 NR 1 : 12 fps
As Rohit said previously also you can get 4 nodes of noise reduction at NR 4 too.
I'm a happy dan with my new system!
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA
Margus Voll
on Mar 23, 2012 at 4:48:55 pm
You are not very popular now ;)
But great results!
Margus
Knut Jansohn
on Mar 28, 2012 at 7:20:01 pm
Hi.
My new gtx 570 (EVGA, HD, 2.5 GB) received today:
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 15 fps
V5 NR 4 : 24 fps
V6 NR 4 : 23.5-24 fps
V7 NR 4 : 12.5 fps
V8 NR 4 : 3.5 fps
MP 4.1, 12 GB, GT120 for GUI
Well compared to the old gtx 285 I am very happy with it :)
Regards
K.
Colin Travers
on Mar 29, 2012 at 1:30:32 pm
Brand New GTX 580 (EVGA 3GB) received yesterday:
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 16.5 fps
V5 NR 4 : 24 fps
V6 NR 3 : 24 fps
V7 NR 2 : 13.5 fps
V8 NR 1 : 4 fps
DaVinci 8.2 OSX 10.7.3
32GB RAM x4 8GB
Software RAID 0 (8TB Internal)
Nvidia GT120/GTX580
BMD Extreme3D
Blase Theodore
on May 1, 2012 at 7:36:03 am
580 Ultra (3g) flashed by David P to 5.0gts.
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
Basically same as the standard 580.
