Looking for a confirmation of an unexpected Input/Sizing behavior.
COW Forums : DaVinci Resolve
Dmitry Kitsov
on Mar 17, 2012 at 11:55:39 pm
In 8.2 if any type of zoom/pan/tilt applied to a clip, when "Basemem" any of the nods all of the sizing resets as well? Didn't it used to be independent of the nodes? If it is now a nod dependent operation why does a reset happens regardless of which node the "Basemem" happens to?
Could someone confirm?
Gabriele Turchi
Re: Looking for a confirmation of an unexpected Input/Sizing behavior.
on Mar 18, 2012 at 2:45:03 am
Same behavior on my system ..
I actually emailed support about it couple of days ago ...
No answer yet ...
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Dmitry Kitsov
on Mar 18, 2012 at 4:58:50 am
Thank you. I think it is a new behavior.
Gabriele Turchi
on Mar 18, 2012 at 5:02:52 am
feel if it is designed this way ... i really don't like it ...i use the base mem button in the davinci panel a lot ... and so i lose the PTZR ...
hope they change it/fix it
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Rohit Gupta
on Mar 18, 2012 at 11:14:43 am
There is a function in the Session menu - "All/Color/PTZR". There is also a button on the control surface called Current Mode I believe.
This control the behavior of a few things:
1. Basemem - will reset all, current node, or sizing
2. Add Mark/Dynamics - will add to all, current node or PTZR/Sizing
3. Copying grade from stills and memories - will copy both, color or sizing only
Hope this helps!
Gabriele Turchi
on Mar 18, 2012 at 2:31:08 pm
mmm... i always use that button , and i usually stay parked in "color" so when i add dynamics it effect only that node ,
so basically when she use a zoom tool we should stay parked in PTZR in order to apply the zoom only to that node ?
i will try on monday ...
thanks a lot
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Gabriele Turchi
on Mar 19, 2012 at 12:05:50 am
ok just tried ,
it works as rohit described , to reset anything but PTZR the ALL/COLOR/PTZR have to be parked on color
thanks
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Dmitry Kitsov
on Mar 19, 2012 at 12:48:11 am
Thank you very much. Can't believe I could overlook something so obvious.
