ACES Render
COW Forums : DaVinci Resolve
Jon Dobson
ACES Render
on Mar 14, 2012 at 4:43:48 pm
Hi there,
I have finished grading a project and I am rendering out as usual to an uncompressed quicktime.
However, I graded this project on the ACES colour science and now when I export the video file created is black crushed. (I have tried codecs too inc pro res)
Do I need to apply an outgoing ACES LUT to convert the colour space back to RGB?
Thanks in advance,
Jon
Dan Moran
Re: ACES Render
on Mar 14, 2012 at 5:14:55 pm
Hey Jon,
Have you made sure to have the Rec709 output transform on when grading?
It should all flow nicely for you then.
Hope this helps!
D
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA
Chris Martin
Re: ACES Render
on Mar 14, 2012 at 5:37:04 pm
Assuming you were grading in rec709, 64-940, it sounds like you're getting quicktimes that are getting stretched to full range (0-1023) rather than SMPTE (64-940).
If you graded in rec709 then hopefully you had rec709 selected as an output device transform in the settings.
Jon Dobson
Re: ACES Render
on Mar 14, 2012 at 8:19:58 pm
Ah I see!
Thanks for the help!
Jon
