New NVIDIA driver for Mac OSX Lion 10.7.3
COW Forums : DaVinci Resolve
Rohit Gupta
on Feb 29, 2012 at 7:55:45 am
NVIDIA has released an updated driver for Mac OSX Lion 10.7.3. It can be downloaded at:
http://www.nvidia.com/object/macosx-270.00.00f01-driver.html
The good news is this update seems to provide CUDA support on OS X for all CUDA capable NVIDIA cards including the GTX580.
We have tested this and it works well for Resolve on Mac OS X.
We were using a configuration with 3 x GTX 580 on a Cubix Desktop 4 with a GT120 GUI GPU, and we could get 25 nodes of image blur processing at 24fps, or 4 nodes of noise reduction at the default settings.
Ola Haldor Voll
Re: New NVIDIA driver for Mac OSX Lion 10.7.3
on Feb 29, 2012 at 8:24:28 am
Are you saying I don't need to hack a kext file or whatever it is, and just install a regular PC version of the GTX 580?
Rohit Gupta
on Feb 29, 2012 at 8:46:36 am
We are just using the regular PC version of the GTX 580.
Ola Haldor Voll
on Feb 29, 2012 at 8:53:19 am
Awesome! I'll have to reconsider a Cubix over a PC then.
Margus Voll
on Feb 29, 2012 at 9:45:17 am
Only benefit now is only internal data lane speed for pc ?
Margus
http://iconstudios.eu
Ola Haldor Voll
on Feb 29, 2012 at 9:26:48 am
I'm talking to a reseller of the Cubix Desktop 4 now. He wasn't sure if it could fit 3 GTX 580 cards. Do you have a special model? He said it would fit 2 double width cards, and 4 single..
Rohit Gupta
on Feb 29, 2012 at 10:17:51 am
The Desktop 4 has 4 double-wide slots. You can refer to our configuration guide on our website for the exact model number.
On PC/Linux, we use 4 double-wide GPUs, but the Mac Pro is limited to a total of 4 GPUs, so one for GUI, and 3 for CUDA compute.
Ola Haldor Voll
on Feb 29, 2012 at 10:24:04 am
Aah OK. It becomes less tempting to go the Windows route now. Can't stand the thought leaving Mac for Windows. At least not now.
Would I be able to install three GTX580 and a Red Rocket?
Erik Lindahl
on Feb 29, 2012 at 4:27:01 pm
This is very very interesting!
Is this officially supported now is did they just happen to make it work?
Lee Niederkofler
on Feb 29, 2012 at 11:52:35 pm
@Would I be able to install three GTX580 and a Red Rocket?
Yes I think you should bea able to do that Ola. I've now 2x470, 1redRocket and one 4LaneEsata card in it and it works like a charm. Space is enough in the Desktop 4 for 4 double space cards
Eric Fiegehen
on Mar 9, 2012 at 8:57:40 pm
Desktop 4 will host up to 4x GTX 580 cards. ***make sure you order the standard exhaust fan part number, XPDT-X16-4-INT or -OSV for No. America***
Eric Fiegehen
Director, Visualization & GPU Compute Solutions
Cubix Corporation
ericc@cubix.com
http://www.cubixgpu.com
Gabriele Turchi
on Mar 9, 2012 at 9:09:50 pm
hi eric
what is different in the exhaust fan model ?
i have a desktop 4 but not quite sure if is that one , and what would be the difference (when i bought it the only other option was the quite fan (but was out of stock)
thanks
g
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma
Eric Fiegehen
on Mar 9, 2012 at 9:26:09 pm
Hi Gabrielle,
The standard exhaust moves more air than the quiet fan part number does. It also makes more noise (about 10db higher) than quiet fan exhaust part numbers (which only makes sense - more air flow, more noise)
Eric
Gabriele Turchi
on Mar 9, 2012 at 9:31:27 pm
that is the one i have ..
how about the different power supply ?
seems that the regular one have 750w and the QF version is 1200W
http://www.cubixgpu.com/Online-Store
is 750W ok for 4 GTX 580-or 590 ?
thanks
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Gabriele Turchi
on Mar 9, 2012 at 9:32:32 pm
ops...my bad ...750W was the cibix II ...not 4
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Eric Fiegehen
on Mar 9, 2012 at 9:33:39 pm
Both part numbers use the 1200w power supply, so you're good for power.
Jamal Watts
on Feb 29, 2012 at 12:56:03 pm
Interesting. So, I have a 3,1 MP with the stock ATI Radeon HD 2600. I want to move this MP from FCP 7 and Color to FCP X and Resolve Lite with a side-order of Avid MC6. I would like to run on the stock PSU and be able to go to Windows on bootcamp with no issues. What should I buy?
Jamie Allan
on Feb 29, 2012 at 5:10:07 pm
My concern here is that Apple can quite easily pull the plug with 10.7.4
Also doesnt help that 10.7.3 causes lots of issues
Despite that, this is good news and hopefully we'll see more of this
I'm going to see what nvidia/pny have to say officially about it
Jamie Allan
Post Production Consultant
DaVinci Specialist (Linux/Mac)
Jamie@Jigsaw24.com
Jigsaw Systems Ltd. - IT & Broadcast specialists for the UK
http://www.jigsaw24.com
http://www.jigsawbroadcast.com
Erik Lindahl
on Feb 29, 2012 at 6:04:55 pm
Would be cool to hear your findings. MacOSX-support for Quadro 5000 and 6000 would potentially be interesting as well.
As you say though, I wouldn't want to invest X-thousand $ finding the solution rendered useless by apple in a month or two. Also, it would be interesting to know how wide the support is in terms of OpenCL, OpenGL, Quartz and of course CUDA acceleration.
Rohit Gupta
on Mar 5, 2012 at 12:23:28 pm
So we have run more tests, this time without a Cubix expansion, and with just a GT120/Mac and a GTX570/PC inside a Mac Pro.
At HD, we could 11 nodes of image blurs at 24fps.
In the Mac Pro, we also have the Red Rocket card and the Decklink card in the x4 PCI-E slots.
Fred Ricci
on Mar 5, 2012 at 3:23:54 pm
Hi Rohit
How do you connect the 8 pin pci cable from the 570?
NEHALEM OCTO 2,26
GT 120
GTX 285
8 Giga RAM
SOFT RAID 8 Tera
Wave
Eizo 243 + Hdlink displayport
DAV, COLOR, FINAL CUT AND MEDIA COMP
Mikhail Puzyrev
on Mar 5, 2012 at 5:19:42 pm
You should throw out dvd. Then you can connect the 6 pin - to molex using dvd power.
Fred Ricci
on Mar 5, 2012 at 7:16:53 pm
Thanks Mikhail, I'll give it a look.
The thing is I still make dvds from time to time, might be going with an external dvd if the 570 really gives me more realtime power.
NEHALEM OCTO 2,26
GT 120
GTX 285
8 Giga RAM
SOFT RAID 8 Tera
Wave
Margus Voll
on Mar 5, 2012 at 9:20:55 pm
What i did with my 470, i just "merged" 2 cables in the middle.
So generally you have black wires and yellow wires going from one end to the other.
I i did cut one extra cable up and soldered 3 ends again together and
got one cable with extra power output.
Now i still have 2 gpu ports on motherboard but one splits half in the other end
and powers my 4000 and second slot for 470.
Margus
Eric Johnson
on Mar 6, 2012 at 12:52:34 am
Margus, you're running a Q4000 and GTX 470 inside your Mac Pro?
Margus Voll
on Mar 6, 2012 at 7:26:10 am
Yes.
With the Y cable i mentioned.
After installation ups failed :) but machine was working nice so i had to loose this ups unit
as its total power rating was to low. I have to see its numbers when i get to the office again.
In the end of the week i could make photos of the mentioned cable if interested.
I can not comment other gpus and power needs.
Margus
Rohit Gupta
on Mar 6, 2012 at 6:02:42 am
The GTX570 needs only 2 x 6-pin connectors, so is no different from a Q4800/GTX470 in that regard.
Gabriele Turchi
on Mar 6, 2012 at 4:25:24 pm
does this new driver require to delete the graphic powermanagements ketx file?
thanks
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Juan Salvo
on Mar 6, 2012 at 4:26:50 pm
It did not affect my agpm kext
Baixo Miño Estudios
on Mar 13, 2012 at 12:04:44 am
Rohit Gupta which model of mac pro you have ?
Rohit Gupta
on Mar 13, 2012 at 5:01:11 am
I ran my tests on the 2010 Mac Pro (12-core).
Colin Travers
on Mar 14, 2012 at 1:36:58 am
Quick question about the 4000 and 570.
I dont have a cubix but a 12 core with the 120/470 combo.
I have run into my first limitation while trying to render out 5K Epic i get a GPU error - I am told by the BMD team that I would need at least a quadro 4000 with 2GB vram as opposed to the 1280MB my 470 card has. I am grading off r3d obviously but need to render back at full resolution (a mix of 3k & 5k) at ProRes444 or HQ.
I can possibly borrow a friends 4000 tomorrow but first i want to be sure that it will be able to render out 5k ProRes files so as not to waste his time or mine. If it does that is great, BUT my other thinking here is to get a 570 card off ebay or locally here in NY if possible and upgrade my system to Lion in order to use the new drivers from nvidia on the pc version of the 570. I want to be sure I can use the cables my current 470 came with in order to connect properly to my 12-core. Most importantly I want to buy the 'best / beefiest' card I can right now for my 12-core non-cubix setup. Please advise.
Is this card below correct even, and if there is a higher / better card someone can recommend please advise as I am willing to upgrade my system to Lion to get a beefy card in there (i.e. 580)? Also, should i swap my 120 for something else or am i fine - i would need a small card like the 120 to fit in my box).
http://www.ebay.com/itm/EVGA-NVIDIA-GEFORCE-GTX-570-2560MB-320BIT-GDDR5-PCI.....
DaVinci 8.2 OSX 10.6.8
MacPro 12-core 5,1 2.66 Ghz
32GB RAM (x4 owc 8gb sticks)
RAID0 8TB
Nvidia GT120/GTX470
BMD Extreme3D
HDlink3D DisplayPort
Dreamcolor/Panny VT25
Tangent Wave / Wacom
Drivers:
Nvidia Cuda 4.1.29
DecklinkExtreme3D 8.6
HDLink3D DisplayPort 3.5.1
Gabriele Turchi
on Mar 14, 2012 at 3:38:22 am
is the 590 supported ?
the 590 have quite more RAM than the 580 and if i recall correctly for higher resolution project the ram of the GPU is essential (right?)
so is the 590 supported by this new nvidia driver?
thanks
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Juan Salvo
on Mar 14, 2012 at 3:52:42 am
The card is supported. Resolve shows an error box, and the Mac pro power supply can't handle the 590.
Colin Travers
on Mar 14, 2012 at 4:08:48 am
Where best to purchase the correct 570 or 580 card for a MacPro Lion 12-core system online or locally in NY?
RAID0 8TB
Nvidia GT120/GTX470
BMD Extreme3D
Drivers:
Nvidia Cuda 4.1.29
Juan Salvo
on Mar 14, 2012 at 4:16:30 am
See my response to your other post. Newegg.
Gabriele Turchi
on Mar 14, 2012 at 4:11:59 am
but aside for the error box it work properly ?
i am thinking on a cubix ..
g
MacPro
Cubix desktop 4
2 Red Rockets
24GB RAM
HP Dreamcolor
Juan Salvo
on Mar 14, 2012 at 4:16:20 am
Yes other than the error box it does seem to work. It shows up as two seperate gpus and functions as such. Performance for single gpu is on par with 570. But multitask functions like nr kick on the second gpu and perform better. I would recommend the 580 as you get better real world performance. Or better yet wait for 680.
Jesse Kobayashi
on Apr 13, 2012 at 6:04:41 am
Has anyone had a chance to test out one of those ASUS MARS II cards with Resolve? Two 580s on one PCI-E slot. 1024 CUDA cores, 3GB RAM, 384 GB/s memory bandwidth? It could free up some slots...or even dual MARS II cards for quad processors using only two slots?
Could be insane.
Juan Salvo
on Apr 14, 2012 at 9:47:26 am
There would be power issues with MacPro. This would only work in cubix, where slots aren't such an issue.
online editor | colorist | VFX | BD author
http://JuanSalvo.com
