Share mask shape between SliceX effects
COW Forums : CoreMelt Plug-ins
Emmanuel Tenenbaum
on Jan 10, 2014 at 3:46:10 pm
Hello
I have a question concerning SliceX (which so far I find fantastic).
I want to make a shape around an object, apply it a Color Correction AND a Depth of Field correction. If I add two effects from SliceX (Color Correct Shape Mask & Depth of Field Shape Mask), I need to draw the same shape 2 times
Is there a faster way of doing this, by drawing the shape only once ?
Thanks!!!!!
Emmanuel Tenenbaum
http://emmanueltenenbaum.com
Eberhard Ammelt
Re: Share mask shape between SliceX effects
on Jan 10, 2014 at 4:59:45 pm
Hello,
you can do this in the following way:
- Duplicate your clip and put it on top of the original clip in the timeline.
- Then add all the effects you want to apply the same mask to to the copy but don't use a mask in these effects.
- Finally add Shape Mask Layer to the effects which will restrict the copy and its effects to one mask.
Eberhard
Emmanuel Tenenbaum
on Jan 12, 2014 at 10:11:54 pm
Makes sense, but I didn't figure it out by myself. Thanks a lot!!!!!!!
Emmanuel Tenenbaum
