Lock & Load Not working in fcpx 10.1
COW Forums : CoreMelt Plug-ins
Paul Burgess
on Jan 1, 2014 at 8:32:58 pm
Having converted my events and projects in fcpx 10.1 the project loading has lock & ,pad plugin being used and causes fcpx to crash with a warning about lock & Load ..... help
Paul
Eberhard Ammelt
Re: Lock & Load Not working in fcpx 10.1
on Jan 1, 2014 at 9:26:32 pm
Please try the latest Lock & Load update. If the problem persists, please send the crash log to me: eberhard (at) coremelt.com
Eberhard
Paul Burgess
on Jan 1, 2014 at 10:16:31 pm
Ok will do.
I have updated before posting the problem but with no effect.
The strange part is that when I try to remove Lock & Load from the Effects folder and then replace it - it still states it is there in the folder even though it cannot be seen.
Secondly the report refers to a directory under Library/Plug-Ins/*/C2 Loack & L:pad but I have no such folder.
I am sending the report now
Paul
Paul
Dustin Bowser
on Jan 31, 2014 at 8:04:17 am
I'm having the same issue. Updated to 10.1, and now experiencing very frequent crashes. It's been crashing when even Launching FCPX and trying to load a library. Tried trashing FCPX preferences, and tried restarting but it consistently crashed on startup.
I finally got my project to load after I uninstalled Lock & Load, loaded the project, scrubbed around a bit, then closed the project and reinstalled Lock & Load and reloaded the project. Though, I'm experiencing the same crash behavior when I try to render my timeline...
Eberhard Ammelt
on Jan 31, 2014 at 9:39:22 am
Can you please send the crash logs to me: eberhard (at) coremelt.com.
Eberhard
