Tracking Issue
COW Forums : CoreMelt Plug-ins
John Fishback
Tracking Issue
on Nov 8, 2013 at 9:09:33 pm
I'm using Slice X and getting a strange error message. I've drawn a mask inside of which I want apply some color correction. But, when I try to track, the error message says I can't track a generator. But, it's not a generator. It's a video clip. What's going on?
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Roger Bolton
Re: Tracking Issue
on Nov 9, 2013 at 12:52:23 am
Is the clip a compound clip, or an unusual codec? Can you try generating optimized media for the clip first and then tracking it?
Also please try copying the clip into a new project and then tracking it.
John Fishback
Re: Tracking Issue
on Nov 9, 2013 at 1:46:56 am
Thanks for the suggestions. I'll try them tomorrow when I'm back in the office.
John
John Fishback
Re: Tracking Issue
on Nov 13, 2013 at 8:42:48 pm
I believe what was wrong was the problem clip was a referenced clip. I ended up using ClipWrap to create a ProRes file which I imported (and copied) to FCP X. Then, Slice X worked fine. I just love this plugin. I just used it 3 times in a minute-long promo video. A real time saver.
John
