R3D footage turns green when Slice X applied in FCPX
COW Forums : CoreMelt Plug-ins
David Berez
on May 29, 2013 at 10:30:22 pm
. . . but not always.
I suspect this is an R3D problem. If I'm working in proxy and I apply the SliceX "blur" I can track it and it works occasionally. However, when I switch back and forth between proxy and R3D, the clip will go green or black and then I be "unfixable" till I replace it with a new copy from the "event browser."
Is this a known bug? Has anyone else had luck using Slice X with R3D's and FCPX?
Thanks for your help.
David
Roger Bolton
Re: R3D footage turns green when Slice X applied in FCPX
on May 29, 2013 at 11:14:53 pm
Can you please try generating optimized media and then seeing if that fixes the problem?
Freelance: Flame - Smoke - Resolve - Nuke - VFX Supervision
Owner / Director: CoreMelt Plugins
