Jello like pixelation
COW Forums : CoreMelt Plug-ins
Scott Sal
on Oct 30, 2012 at 9:38:13 pm
I'm trying to use Lock & Load X to stabilize a few clips that seem to be less shaky than those in the tutorial. However, after trying multiple attempts at tracking motion within and outside the rectangle (focusing on the background) and using full frame, I'm getting jittery pixels in the clip. It keeps happening, and has happened on every clip I try to use Lock and Load. I'm using clips from a 5d mk II and a t2i and use the shutter reduction and stabilizing operation mode. The footage is converted to ProRes 422. Some help would be greatly appreciated
Roger Bolton
Re: Jello like pixelation
on Oct 31, 2012 at 12:08:30 am
Hi, we would have to see the footage to offer advice. Can you please email us at support at coremelt dot com and we will try to help you.
CoreMelt V2 plugins
Scott Sal
on Nov 1, 2012 at 8:58:11 pm
Email sent
Scott Sal
on Nov 1, 2012 at 8:59:59 pm
If this gets seen first: Here's the clip im working https://vimeo.com/52644407
The first clip is original footage, second is stabilized and shutter reduction, and the third is just shutter reduction.
Thank you!
Eberhard Ammelt
on Nov 2, 2012 at 9:26:36 am
It's strange that it renders correctly with shutter reduction only but not with stabilization because the render unit is the same in both cases. Are there any other differences between both cases, e.g. other plugins applied or different clip or project settings?
Eberhard
Scott Sal
on Nov 2, 2012 at 6:42:51 pm
There are no other differences. I'm at a loss, I've been working with Roger and sent him the clip. Hopefully he can figure out what I'm doing wrong.
Roger Bolton
on Nov 7, 2012 at 12:59:06 am
The issue was specific to the conversion from h264 to prores, the method used was introducing fields. We recommend in Premiere Pro and FCP X that customers work directly with the h264 files and on FCP7 make that your conversion process does not introduce fields into the footage.
CoreMelt V2 plugins
