Lock & Load
COW Forums : CoreMelt Plug-ins
Mike Gilligan
Lock & Load
on Nov 30, 2009 at 9:22:38 pm
Hi, I can't make Lock & Load work.
I have a Mac Pro 8-core, CalDigit 4tb raid drives, an AJA iO Hd box and I'm running Studio 3.
I just bought the Lock & Load, installed & registered it.
1.) I selected a 6-sec. clip which was locked off, with slight rotation & movement. (An easy one.)
I selected the clip and put the cursor on it.
2.) I clicked "Tracking" & it did it's thing. (The "Stabilization Mode" was grayed out until it tracked.)
3.) I change the default "Stabilization Mode" from "Multi Shot to "Lock Down"
4.) There is no stabilization when using "Multi Shot" and with "Lock Down," I get no stabilization, but lots of jitter, with frames of black blinking on and off. The same is approximately true with other Stabilization Modes and other clips. I tried bypassing the AJA and changing the FCP setups to DV NTSC and got the same thing. What am I doing wrong?
Mike
P.S. I have religiously read the instructions.
Michael G
