Lock and Load X doesn't work for clips with connected audio clips
COW Forums : CoreMelt Plug-ins
Alex Grainger
on Aug 21, 2012 at 8:38:14 pm
I had a clip with an audio file as a connected clip, and I was not able to click the "Track Motion" button on the effect.
After an hour of pulling my hair out, I realised that the reason is the clip has an audio file as a connected clip. Once I moved the connection point of the audio clip to another clip that didn't need stabalizing (using Cmd + Option) I was able to click "Track Motion".
Hopefully this will get addressed in an upcoming update.
Roger Bolton
Re: Lock and Load X doesn't work for clips with connected audio clips
on Aug 21, 2012 at 11:41:42 pm
Thanks Alex, we have a fix for this underway. For now move the audio to connect to another clip, hit track, then move the audio back to where you want it.
Once Lock & Load has the tracking data it works fine with any connected audio or other clips.
We should have a new version out very soon to fix this.
CoreMelt V2 plugins
