Lock & Load X test version for FInal Cut Pro X
COW Forums : CoreMelt Plug-ins
Roger Bolton
on Aug 6, 2012 at 5:25:47 am
Hi, Lock & load will soon be available for Final Cut Pro X, we know some of you have been waiting a while for this.
We have a test version available, its stable and much much faster than the built in stabilize in Final Cut Pro X. If you would like to try it out, please contract us direct: email us at: support at coremelt dot com
CoreMelt V2 plugins
Mikey Bouchereau
Re: Lock & Load X test version for FInal Cut Pro X
on Aug 17, 2012 at 5:17:26 pm
Does Lock and Load X work with compound clips or multicam clips?
Mikey B!
Follow Me On Twitter!
Download Free Effects/Transitions/Generators for Final Cut Pro X
Check Out My Sky Replace Tutorial
Iain Anderson
on Aug 17, 2012 at 11:56:39 pm
It does work with Compound clips, but you'll get better results stabilizing each clip with the compound rather than trying to do the whole lot at once.
Multicam is a little different; you can stabilize any clip on the main timeline (multicam or not) so you should be OK. However, you can't access the HUD within the angle viewer to Track Motion for an entire angle, at least not without some workarounds.
Roger Bolton
on Aug 18, 2012 at 12:17:56 am
Hi Iain, the method to accessing the On screen controls within the angle viewer is covered in the docs.
Just click on the viewer icon for the angle and the clip and the plugin controls and it should be displayed. Otherwise toggle the transform controls on and off and it shows up.
CoreMelt V2 plugins
Roger Bolton
on Aug 18, 2012 at 12:14:25 am
yes to both, there are some restrictions which are covered in the docs.
CoreMelt V2 plugins
Alex Grainger
on Aug 21, 2012 at 11:01:21 am
Please could you post a link to the docs or manual, as I can't find it on the website?
Roger Bolton
on Aug 21, 2012 at 11:06:55 am
The PDF Help document is accessed by pressing the "click for help" button in the plugin onscreen control after installation. They are not currently online on our website but there is a detailed video tutorial here:
http://www.coremelt.com/lockfcpx/
CoreMelt V2 plugins
