L&L rendering Vs. smoothcam
COW Forums : CoreMelt Plug-ins
Gabriele Sartori
on Nov 22, 2009 at 3:09:36 pm
Installed, tested, it works great. A big question though, do I have to render the clip every time?
smoothcam doesn't need that. If I change my zoom a bit I can see it right away. This way I lose most of the gain in my editing process. Or is this just a limitation for the trial version?
I'm ready to buy it but this could be the showstopper.
Let me know if I do something wrong.
Gabriele
Roger Bolton
Re: L&L rendering Vs. smoothcam
on Nov 22, 2009 at 11:33:43 pm
Hi, lock and load can preview in realtime if you have your timeline set to UnlimitedRT. You should get an orange bar on the timeline and then be able to see the result of Lock & Load playing in in realtime.
Likewise, when dragging a parameter you should see the change to the image updating as you drag the slider.
You can turn on "Unlimited RT" from the RT tab on the top left of your timeline.
Please try that.
CoreMelt V2 plugins
Gabriele Sartori
on Nov 22, 2009 at 11:53:26 pm
Thanks, it works as you described indeed. Stupidly I didn't think at this . Thank you very much.
Gabriele
Roxana Brivent-Barnes
on Apr 9, 2010 at 10:49:55 am
Hi
I just turn on unlimited RT and I cannot play the footage at all, the frames are droping, can you advice what shall I do?
Thank you,
Roxana B-B
Eberhard Ammelt
on Apr 9, 2010 at 1:55:23 pm
Hello,
what are your sequence settings, and what is the codec of your source video?
Regards,
Eberhard
on Apr 9, 2010 at 2:12:32 pm
Hi Eberhard
I am using safe Rt, and I am using Sony HD Z7, sorry for not being very helpful with details, I am not techy at all.
Thanks for such a fast reply,
Roxana B-B
Eberhard Ammelt
on Apr 9, 2010 at 2:27:28 pm
Hello Roxana,
unlimited RT is alright, but the actual frame rate may depends on several settings and your computer's hardware. Do you see an orange line above the clip in unlimited RT?
Could you send a screen shot of your sequence settings?
Eberhard
