Lock & Load can't render on this hardware
COW Forums : CoreMelt Plug-ins
Roman Heer
on Jul 12, 2012 at 6:43:39 pm
Hi
With our "Lock & Load" 2.x it prompts the message "Can't render Lock & Load" on this hardware" If we use AppleProRes 422 footage on the timeline of FCP 7.0.3 on OSX 10.6.8.
We use a MacPro 2.1 with 8 cores and a NVIDIA GeForce 7300 GT.
We want purchase the CoreMelt Complet package, but first this must be fixed!
Roman
Roger Bolton
Re: Lock & Load can't render on this hardware
on Jul 13, 2012 at 12:02:53 am
Hi, this problem is a limitation of your current graphics card. The Nvida 7300 GT is a very low level graphics card and when you are using full HD video with two displays and 10 bit color FCP runs out of VRAM space.
The solutions are:
disconnect your second display then try to render
set your sequence settings to render in 8 bit YUV under the video processing tab
buy a new graphics card
Other plugins should render ok but Lock & Load needs additional VRAM space as it processes a large number of frames in order to do stabilization correctly.
CoreMelt V2 plugins
Roman Heer
on Jul 13, 2012 at 7:12:31 am
Hi
That message we get only with AppleProRes 422 in HD.
We don't want change our MacPro at the moment (better waiting to next year...)
But we could upgrade our graficboard of that MacPro 2.1.
What would better work with CoreMelt Complet V2? (and AfterEffects, FCP anyway)
Nvidia
-GeForce 8800 GT?
or a
-Quadro FX 4500?
Thanks for your advice
Roman
Eberhard Ammelt
on Jul 13, 2012 at 5:20:18 pm
Hello,
this is an estimate by FCP, Lock & Load itself doesn't depend on the codec being used.
I can only confirm that our plugins work well with the GeForce 8800 GT.
Regards, Eberhard
