poorly stabilized pan
COW Forums : CoreMelt Plug-ins
John Reis
on Apr 2, 2012 at 1:55:11 am
So I have a bunch of pans, that come out looking very 'stagey', the pans are not smooth, like the tripod was grabbing as the camera man panned.
Can I fix this with Lock and Load. Ive never used the Lock & Load for something like this, and Im nervous the footage might be unusable.
FCP Tracker seems to do a decent job, but not quite, so not good enough either. So far Lock & Load is not working as well,
Eberhard Ammelt
Re: poorly stabilized pan
on Apr 2, 2012 at 11:00:27 am
Hello,
yes, you can stabilize panning motion with Lock & Load.
Regards, Eberhard
John Reis
on Apr 2, 2012 at 12:51:05 pm
Is there a settingI don't know about? So far FCP does a much better job, and Lock & Load makes it worse. Advice would b helpful
Eberhard Ammelt
on Apr 2, 2012 at 1:01:09 pm
There's no particular setting for panning motion. What is the exact problem?
Can you please upload a demo?
Eberhard
John Reis
on Apr 2, 2012 at 1:21:44 pm
The speed of the pan is uneven and jerky, Ive only used the plug in to steady handheld shots. This is diferent
Eberhard Ammelt
on Apr 2, 2012 at 1:32:42 pm
I would need to see your video before I can tell what might be the problem.
Eberhard
John Reis
on Apr 2, 2012 at 2:13:09 pm
I just want to fix a jerky pan
is that too hard to understand
thanks for the non help
Roger Bolton
on Apr 2, 2012 at 2:19:02 pm
We're not trying to be difficult but we can't really help you with the info you've given. I stabilise pans all the time with Lock & Load and they work.
If yours doesn't work theres something unique about the codec or the sequence settings, if we see the footage we can try and help you. Check your sequence settings in particular, Lock & load gives bad results if you set the wrong field dominance and FCP gets confused by some codecs and gets the field order wrong (thinks there is field where there isn't)
Without seeeing your footage we can't be more specific than that
CoreMelt V2 plugins
John Reis
on Apr 2, 2012 at 2:42:51 pm
Like i said it was a mucked up tripod pan, its not the codec. oh brother
Roger Bolton
on Apr 2, 2012 at 3:00:03 pm
No, the reason that Lock & Load is not working properly could be the codec setting could be many things, but we can't help you because you won't give us enough information.
You apply Lock & load and it smooths the clip, there's nothing special for a jerky pan. if it's not working, then something has gone wrong, we need info from you if you want us to help you.
CoreMelt V2 plugins
Roger Bolton
on Apr 19, 2012 at 3:58:53 am
Theres some examples of complex Pans with jerky motion in the latest video here:
http://www.coremelt.com/reviews/news/106-lock-and-load-nab-2012.html
Nothing special had to be done to make these work.
CoreMelt V2 plugins
Greg Vaughan
on Mar 13, 2014 at 12:38:47 am
For what it's worth, I'm having the same problems. I have several clips that were shot with a slide and I can't remove the jerkiness with any settings in your plugin in an FCPX project. Even using extreme settings, I can't tell any difference. It's not even clear that Lock & Load is doing anything to impact the jerkiness.
Eberhard Ammelt
on Mar 13, 2014 at 8:50:44 am
Hello,
you should clearly see a difference unless you set stabilization strength to 0.
I assume Lock & Load did track without error message?
Can you please check the system log for error messages from FCP X and send them to me: eberhard (at) coremelt.com ?
Regards, Eberhard
