L&L frames - FCP 7 rendering issue - white frames
COW Forums : CoreMelt Plug-ins
David Masher
on Jan 11, 2012 at 3:04:51 pm
Hi there, two things:
1. I am having an issue where when I render a stabilized sequence that includes an imported Apple Motion track, with an alpha above the track I am stabilizing, it renders full screen white about 80 percent of the time. I am using the Motion file as a lower third. When I turn off the Motion track it renders perfectly.
2. I am trying to find the coefficient for a goPro Hero 2 for use with shutter reduction. There was a video on your site but the page seems to be gone.
Thanks for you help!
David
Eberhard Ammelt
Re: L&L frames - FCP 7 rendering issue - white frames
on Jan 12, 2012 at 2:25:42 pm
Hello,
ad 1:
I can't reproduce this problem. When you say it's white 80% of the time, is it erratic?
Can you please check the log file for possible error messages? If there are no error messages, can you please tell your sequence settings?
ad 2:
You can find the instructions for estimating the optimum camera coeffcient on page 7 of the help pdf.
We'll check and repair the link to the related video tutorial.
Regards, Eberhard
David Masher
on Jan 12, 2012 at 9:14:15 pm
Hi, thanks for the response! I did not realize I had project and footage mismatched... It seem to be fine now. Thanks
