Lock and Load X under Lion
COW Forums : CoreMelt Plug-ins
Federico Urdaneta
on Jul 28, 2011 at 1:14:50 pm
Hey there
Im running FCP studio (latest version 7.0.3 I believe) under Mac OS Lion and the Lock and Load plugins don't seem to work correctly.
If I try Lock and Load X I get an error message saying "XML Translation aborted due to critical error" and then "An error ocurred while reading clip properties"
If I try Lock and Load Frames I get "Motion tracking error, Could not read frames. If DCD is enabled please switch it off..."
So it's unusable right now. Any ideas?
Federico
Eberhard Ammelt
Re: Lock and Load X under Lion
on Jul 29, 2011 at 12:40:46 pm
Hello,
the error message that comes up with Lock & Load X is related to XML conversion in FCP. This problem can happen with rather complex projects when memory gets low. As this is a problem of FCP not Lock & Load, I recommend to use Lock & Load Frames instead.
Regarding the Lock & Load Frames error could you please send the log messages?
Do you have a 2nd display in use with FCP? If yes, can you disable it?
You can also try to preliminarily delete the FCP preferences.
Regards, Eberhard
Federico Urdaneta
on Jul 29, 2011 at 12:46:30 pm
Hey Eberhard
Thanks for your reply.
I've already deleted FCP preferences, to no avail. And this is the VERY LONG console output when Lock+Load Frames crashed:
29/07/2011 13:44:15.401 Final Cut Pro: ProKit's NSWindow addition -setActiveAppearanceDuringRestore: has been deprecated and does nothing on SnowLeopard for apps linked on ProKit 5.x or later. Please remove this method call.
29/07/2011 13:45:23.107 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.107 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.107 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.108 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.108 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.108 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.109 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.109 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.109 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.110 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.110 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.110 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.111 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.111 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.111 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.112 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.112 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.112 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.113 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.113 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.113 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.360 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.360 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.360 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.383 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.383 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.383 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.407 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.407 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.407 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.430 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.430 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.430 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.461 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.461 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.461 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.499 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.499 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.499 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.529 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 13:45:23.529 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.529 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.542 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:23.542 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.542 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.709 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:23.709 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.709 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.787 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:23.787 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.787 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.861 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:23.861 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.861 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:23.944 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:23.944 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:23.944 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.029 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.029 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.029 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.036 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.036 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.036 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.112 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.112 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.112 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.120 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.120 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.120 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.203 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.203 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.203 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.211 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.211 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.211 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.297 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.297 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.297 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.305 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.305 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.305 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.378 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.378 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.378 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.385 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.385 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.385 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.393 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.393 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.393 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.478 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.478 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.478 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.486 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.486 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.486 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.493 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.493 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.493 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.578 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.578 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.578 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.586 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.586 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.586 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.593 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.593 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.593 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.678 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.678 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.678 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.685 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.685 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.685 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.693 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.693 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.693 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.777 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.777 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.777 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.784 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.784 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.784 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.792 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.792 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.792 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.799 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.799 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.799 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.877 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.877 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.877 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.885 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.885 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.885 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.892 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.892 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.892 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.901 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.901 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.901 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.978 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.978 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.978 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.985 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.985 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.985 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.992 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.992 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.992 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:24.999 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:24.999 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:24.999 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.079 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.079 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.079 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.086 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.086 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.086 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.094 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.094 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.094 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.101 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.101 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.101 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.177 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.177 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.177 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.185 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.185 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.185 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.193 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.193 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.193 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.200 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.200 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.200 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.209 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.209 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.209 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.296 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.296 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.296 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.305 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.305 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.305 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.314 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.314 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.314 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.322 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.322 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.322 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.330 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.330 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.330 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.411 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.411 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.411 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.419 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.419 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.419 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.426 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.426 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.426 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.434 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.434 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.434 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.442 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.442 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.442 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.526 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.526 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.526 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.533 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.533 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.533 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.540 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.540 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.540 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.548 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.548 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.548 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.557 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.557 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.557 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.645 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.645 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.645 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.652 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.652 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.652 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.659 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.659 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.659 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.667 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.667 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.667 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.674 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.674 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.674 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.682 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.682 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.682 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.761 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.761 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.761 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.768 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.768 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.768 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.776 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.776 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.776 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.783 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.783 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.783 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.790 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.790 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.790 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.797 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.797 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.797 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.878 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.878 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.878 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.885 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.885 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.885 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.892 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.892 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.892 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.899 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.899 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.899 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.907 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.907 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.907 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.914 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.914 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.914 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:25.994 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:25.994 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:25.994 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.001 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.001 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.001 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.009 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.009 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.009 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.016 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.016 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.016 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.024 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.024 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.024 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.031 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.031 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.031 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.130 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.130 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.130 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.138 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.138 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.138 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.145 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.145 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.145 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.153 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.153 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.153 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.161 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.161 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.161 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.169 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.169 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.169 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.176 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.176 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.176 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.260 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.260 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.260 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.268 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.268 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.268 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.277 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.277 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.277 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.285 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.285 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.285 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.294 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.294 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.294 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.302 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.302 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.302 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.311 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.311 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.311 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.411 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.411 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.411 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.418 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.418 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.418 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.426 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.426 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.426 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.433 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.433 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.433 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.441 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.441 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.441 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.449 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.449 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.449 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.456 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.456 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.456 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.526 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.527 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.527 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.534 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.534 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.534 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.542 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.542 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.542 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.550 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.550 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.550 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.558 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.558 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.558 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.565 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.565 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.565 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.573 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.573 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.573 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.662 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.662 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.662 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.670 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.670 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.670 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.678 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.678 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.678 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.686 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.686 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.686 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.693 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.693 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.693 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.701 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.701 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.701 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.709 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.709 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.709 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.716 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.716 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.716 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.797 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.797 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.797 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.804 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.804 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.804 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.812 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.812 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.812 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.819 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.819 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.819 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.827 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.827 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.827 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.835 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.835 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.835 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.843 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.843 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.843 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.850 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.850 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.850 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.944 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.944 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.944 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.951 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.951 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.951 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.958 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.958 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.958 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.966 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.966 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.966 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.973 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.973 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.973 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.981 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.981 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.981 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.989 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.989 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.989 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:26.996 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:26.996 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:26.996 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.076 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.076 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.076 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.084 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.084 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.084 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.091 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.091 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.091 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.099 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.099 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.099 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.107 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.107 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.107 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.115 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.115 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.115 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.123 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.123 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.123 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 13:45:27.130 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6221824) failed (error code=12)
29/07/2011 13:45:27.130 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 13:45:27.130 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
Eberhard Ammelt
on Jul 29, 2011 at 12:56:36 pm
Ok, thanks.
FCP failed many times to allocate only 6 MB which is about the size of a HD frame. When memory is that low, FCP and/or a plugin gets into trouble.
If this happens during motion tracking, FCP cannot provide the requested frame to Lock & Load Frames.
I can only recommend to reduce the memory footprint of your project.
Do you have a complex project, with long timeline and/or many effects applied?
Can you e.g. split your project?
Regards, Eberhard
Federico Urdaneta
on Jul 29, 2011 at 1:04:30 pm
Well I have 24 GB of RAM (though I know FCP cannot access more than 4, still).
And yes, the project is pretty complex.
So I just created a new project to deal just with stabilizing clips. LL FRAMES works OK (most of the time, not always), but watching the console the same MALLOC message appears.
In this new, simple project, LL X still doesn't work and gives me this on the console:
29/07/2011 14:03:10.756 helpd: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
29/07/2011 14:03:48.620 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=6234112) failed (error code=12)
29/07/2011 14:03:48.620 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 14:03:48.620 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
29/07/2011 14:03:58.374 [0x0-0x18e18e].com.apple.FinalCutPro: Final Cut Pro(1797,0x3d452c0) malloc: *** mmap(size=35647488) failed (error code=12)
29/07/2011 14:03:58.374 [0x0-0x18e18e].com.apple.FinalCutPro: *** error: can't allocate region
29/07/2011 14:03:58.374 [0x0-0x18e18e].com.apple.FinalCutPro: *** set a breakpoint in malloc_error_break to debug
Eberhard Ammelt
on Jul 29, 2011 at 5:30:25 pm
Allocation errors are reported by FCP quite often, but these errors are mostly critical only when it fails to allocate small memory portions like a few MB.
It's strange that this happens in a small project as well. Did you close the big project and then restart FCP?
Eberhard
Rob Moreno
on Jul 30, 2011 at 2:11:03 am
I've had the same experience using Lock & Load under Lion. Seems to be an incompatibilty with Lion because I can open the same project on another Mac running Snow Leopard and it works just fine.
Tokyo
Federico Urdaneta
on Jul 30, 2011 at 12:54:12 pm
Yep. L+L was working perfect under Snow Leopard. I've now resorted to trying out the Warp Engine under After Effects, but I still prefer Lock and Load. The Warp Engine seems to be incapable of stabilizing anything without implementing a 130% scale.
Eberhard Ammelt
Re: Lock and Load X under Lion
on Aug 1, 2011 at 2:12:52 pm
I can reproduce the problem where Lock & Load X shows the message "An error occurred while reading clip properties". It seems that FCP 7 has a specific problem with OS X 10.7. We're working on a solution.
For now I recommend to use Lock & Load Frames instead.
Regards, Eberhard
Rob Moreno
on Aug 2, 2011 at 3:51:13 am
Although Lock and Load Frames does work under Lion, in my experience it produces an inferior result compared to running it under Snow Leopard, and sometimes exhibits quirky behavior when adjusting the parameters. Just FYI.
Looking forward to the fix!
Tokyo
Federico Urdaneta
on Aug 2, 2011 at 9:29:54 am
I agree. I think Lion doesn't really like FCP Studio in general. Bummer. Off to Premiere after this one it seems
Eberhard Ammelt
on Aug 3, 2011 at 11:33:21 am
Update: Apple has confirmed there's a bug in FCP 7 under Lion, which prevents FCP from saving an effect's custom parameter data into a project.
This causes the tracking failure of Lock & Load X together with the error message "An error occurred while reading clip properties".
Several other of our plugins are affected by this problem as well, so we suggest to keep with OS X 10.6 when using FCP 7 with our plugins.
Eberhard
Wacharapong Chiowanich
on Aug 11, 2011 at 1:36:15 am
I too have had similar problems. L&L X would't read the clips. L&L Frames worked only some of the time. Most of the time, though, under the "Smart Zoom" option, it strangely MAGNIFIED the shake by tilting the frame thus forcing excessive zooming at close to the end of the clips. This invariably happened only towards the end of the clips regardless of how dominant subject(s) in the frame behaves or how the camera movement was e.g. static,vertical or horizantal zooming etc.
I have used only L&L X with FCP7 under Snow Leopard and it has always worked fine. Never tried L&L Frames, though.
Federico Urdaneta
on Aug 2, 2011 at 2:46:18 pm
L+L Frames is now crashing FCP most of the time (with just one small project open). The Crash Analyzer from the Pro Maintenance Tools syas:
Plugin
This crash appears to have been caused by the Pixlock Cvl plugin.
Suggested Actions
Render your timeline before playback.
Try to avoid adding too many plugins to a clip. If you must do this, export the finished clip out to a QuickTime movie and reimport into Final Cut Pro.
Disable or remove the plugin with Plugin Manager.
Check with the manufacturer for an update or contact their support department.
Relevant Line
0 com.pixlock.cvl 0x568163ad icvDefaultFree(void*, void*) + 19
Report generated by Crash Analyzer in Pro Maintenance Tools
Eberhard Ammelt
on Aug 3, 2011 at 12:14:05 pm
Can you please send the complete crash log to my address eberhard (at) coremelt.com ?
Due to the FCP bug (see my previous post) Lock & Load Frames might not work reliable as well.
Eberhard
