 | L&L No tracking data using compressor
on May 2, 2011 at 11:11:21 pm |
Hello, I'm getting "no tracking data" over my clips with L&L X when I export using compressor.
I tried making a QT ref file then drag that into compressor, but have general error issues when I try to export whole sequence, which I believe to be unrelated.
I tracked and rendered the clips before adding in/out points to the sequence like I saw in other post. I was having flashing issues but that fixed it.
 | Re: L&L No tracking data using compressor on May 3, 2011 at 6:42:27 pm |
Hello, have you tried Lock & Load Frames and X?
The problem with in/out points only referred to the "Frames" version, but this was fixed a few months ago, so I suggest to try the latest version.
Regards, Eberhard
