Lock&LoadX in AE "forgets" to apply Shutter correction
COW Forums : CoreMelt Plug-ins
Eric Epstein
on Mar 8, 2011 at 7:04:38 am
Hello.
I'm using Lock&Load X [1.1] in AE CS5, the latest version of each I believe.
Seems to work great overall, but I've encountered an odd error.
When I have the Operation Mode set to 'Shutter Reduction only,' the visible effect disappears once the project is re-opened. Enabling and disabling the effect does nothing at that point. But if I set the Operation Mode to anything else and then set it back to Shutter Reduction only, the effect starts functioning properly again. Then I save, close, and re-open and it's disabled again.
So, I am stuck manually re-enabling the effect over and over.
Any ideas why this is happening?
Any possible workarounds?
Eric
Eberhard Ammelt
Re: Lock&LoadX in AE "forgets" to apply Shutter correction
on Mar 8, 2011 at 1:25:08 pm
Hello,
I can reproduce the problem. It seems the internal caches are not correctly updated in this operation mode after re opening. I'll send you an update soon.
Regards, Eberhard
