Lock & Load XML Keeps Exporting
COW Forums : CoreMelt Plug-ins
Frederick Ross
on Dec 16, 2010 at 4:42:36 pm
I have applied the Lock & Load X to a about 30 clips in my timeline, every 3 min or so the "Exporting XML" window pops up and I have to wait for it to finnish. Why is it doing this? I tracked all the motion when I applied the filter to all the clips.
Eberhard Ammelt
Re: Lock & Load XML Keeps Exporting
on Dec 16, 2010 at 7:19:30 pm
Hello,
Lock & Load X requests xml data from FCP to retrieve timing information.
This should only happen when you track motion or when you change clip timing, such as in/out points. Does Lock & Load X trigger xml conversion without this reason?
If a sequence/project is complex and xml conversion time gets annoying, we recommend to use Lock & Load Frames instead.
Regards, Eberhard
